input port bit slect using variable name
Maverick
Has thanked: 27 times
Been thanked: 8 times
Post by Maverick »
Is there a way you can read the value of a port bit using a variable name to select the port bit used.
Has thanked: 724 times
Been thanked: 783 times
Re: input port bit slect using variable name
The easiest way would be to use the switch icon.
Then you can add any input on any branch.
If for example, the value of the switch variable is 2 the branch which has 2 will be accessed.
That could have an input A2 for example
Has thanked: 163 times
Been thanked: 960 times
Post by mnfisher »
An alternative technique...
Read the entire port and then shift to get the required bit..
Have something like:
Where .n is the variable holding the bit you want to read and .p is a variable as 'wide' as the port (so byte for 8 bits or long for esp32 (32 bits port)).
.p = Input() // Read the whole port - click on Advanced options to allow this.
.bit = (.p >> .n)  & 1   // Extract the required bit.
