Help with XC compiler problem
wayne_millard
Has thanked: 1 time
Been thanked: 9 times
Post by wayne_millard »
To all,
I have a problem compiling a project that was made in flowcode6 and now trying to compile in flowcode9 and have the following problems any help would be great.
FCM_RS232_Rx()
9803: if ((rcsta & (1 << FERR)) != 0)
^ (192) undefined identifier "rcsta"
9805: dummy = rcreg;
^ (192) undefined identifier "rcreg"
9814: FCV_RX_BUFF[FCV_RX_BUFF_END] = rcreg;
c: main()
12468: pie1.RCIE=1;
^ (192) undefined identifier "pie1"
^ (196) struct/union required
12469: intcon.PEIE = 1;
^ (192) undefined identifier "intcon"
12470: rcsta |= (1 << CREN);
12471: intcon.GIE = 1;
c: myisr()
13554: if(pir1 & (1 <<RCIF))
^ (192) undefined identifier "pir1"
(908) exit status = 1
Thanks,
Wayne Millard :oops:
kersing
Has thanked: 81 times
Been thanked: 65 times
Re: Help with XC compiler problem
Post by kersing »
Take a look at your C code icons. If you need help it would be best to post the code from them as code block on the forum in stead of having us try to distil th8ngs from the compiler errors.
Has thanked: 778 times
Been thanked: 839 times
Hi Wayne.
FC6 uses boost C which uses lower case for register names.
FC7 and above changed to XC8 which uses upper case for register names.
You will also require a different format.
Eg. instead of
intcon.PEIE = 1;
Use
st_bit(INTCON,PEIE);
For
use
FCV_RX_BUFF[FCV_RX_BUFF_END] = RCREG;
ect.
wayne_millard
Has thanked: 1 time
Hi Martin,
Thanks for the feed back i have now changed all that you said and now have this problem.
12468: PIE1.RCIE=1;
12469: INTCON.PEIE = 1;
12471: INTCON.GIE = 1;
Thanks for the help.
You're welcome.
Yes you will have an issue.
Its to do with
medelec35 wrote:
Fri Jan 22, 2021 9:41 pm
Eg. instead of
intcon.PEIE = 1;
Use
The format of
REGISTER . BIT = value;
will not work.
Best to use the format of
st_bit(REGISTER, BIT) ;
so you will need to use
st_bit(PIE1,RCIE);
instead of
PIE1.RCIE=1;
wayne_millard
Has thanked: 1 time
Hi Martin,
Thanks for your great help.
:D
Wayne Millard
Hi Wayne,
All sorted now?
I have just remembered another way.
I stated
REGISTER.BIT = value;
will not work.
However if you place a lower case
bits
after the register name e.g REGISTERbits.BIT = value;
It will work .
for example, you can use
PIE1bits.RCIE=1;
Other things to note.
You can clear bits with cr_bit instead of st_bit.
If the bit name has a bar above it like this:
The you must precede the bit name with a lower case n.
So to enable weak pull-ups on PIC16F1825 for example, you can use
cr_bit(OPTION_REG,nWPUEN);
or
OPTION_REGbits.nWPUEN = 1;
jan.didden
Has thanked: 20 times
Been thanked: 12 times
Post by jan.didden »
This had stumped me some time: how to name a bit called (overbar)WPPU in the data sheet.
Of course: OPTION_REGbits.nWPPU = 1 !
Thanks (again) Martin.
Jan Didden
Hi Jan.
You're welcome.
Microchip does not make it that easy to work out.
Thanks for letting me know I have helped.
Has thanked: 637 times
Been thanked: 847 times
If you ever need to know the specifics for a PIC device then the easiest way is to look at the .h file in the compiler pic/include/ directory.
For example for the 16F877A I looked at the pic16F877a.h file.
Then search the file for the register your interested in, here is the section for the OPTION_REG register.
#define OPTION_REG OPTION_REG
extern volatile unsigned char           OPTION_REG          @ 0x081;
#ifndef _LIB_BUILD
asm("OPTION_REG equ 081h");
#endif
// bitfield definitions
typedef union {
    struct {
        unsigned PS                     :3;
        unsigned PSA                    :1;
        unsigned T0SE                   :1;
        unsigned T0CS                   :1;
        unsigned INTEDG                 :1;
        unsigned nRBPU                  :1;
    struct {
        unsigned PS0                    :1;
        unsigned PS1                    :1;
        unsigned PS2                    :1;
} OPTION_REGbits_t;
