Hi!
I am using the ACS 712 20 sensor with Arduino Uno. This has been working but now not anymore?
It work perfect in simulation but not in real.
The display show by: 0,0Amp >24,75. by 1,0Amp > 25,74. by 2,0 Amp > 26,74
If I add this calculation in a calculation: Amp = Amp - 24,74 it work perfect?
For me it look like the ref voltage out of ACS712 on 2,5V is removed in the calculation for the ACS component? Please advice.
Br jorgen
ACS712 20A
- Has thanked: 839 times
- Been thanked: 205 times
- Has thanked: 724 times
- Been thanked: 783 times
Re: ACS712 20A
Hi Jorgen.
The readings you are getting are caused by the incorrect VDD properties setting.
instead of 501.00 for VDD of 5.01V, you need to enter 5.01 instead.
The reference voltage has not been removed, there have been no recent changes.
Re: ACS712 20A
Hi Martin!
Ok I thought it was ok, this is what the proporties i comes up with default when choosing the ACS component. Again I will follow your advice, also concerning the ESP32. Again I "out" and is first able to test on thursday and you hear from me.
Thank´s Martin
Br Jorgen
Thank´s Martin
Br Jorgen
Re: ACS712 20A
Hi Martin!
Perform a test with 5.01 Volt. Again you are rigth it work, no bug. Will you tell me what the Vref. is doing?
I perform the test with the ESP32 tomorrow
Thank´s in advance
Br Jorgen
Thank´s in advance
Br Jorgen
- Vref.PNG (2.14 KiB) Viewed 3327 times
Re: ACS712 20A
Hi Martin!
I need a to measure a bigger value than 20Amp so therefor I now use ACS758 LCB- 50U
The output of the analog out when 0 amp. Offset is0,640V and the mV increase with 60mV/Amp.
When I connect the output to the arduino without load, the display show -47,4 amp.
If I connect a potmeter (divider with 5V) and connect to the Arduino I the display first show 0,0V with input of 2,5V and it look like 0,020V/Amp
Have I done anything wrong or can I adjust it in Properties. Please.
Br Jorgen
Br Jorgen
- MartinACX50AmpOK.fcfx
- (10.85 KiB) Downloaded 112 times
Re: ACS712 20A
Hi Jorgen.
The reason you are having issues is because the ACS758 Flowcode component is bidirectional.
The component you are using is unidirectional, hence the current reading when no current is flowing.
I will see what I can do for you.
Re: ACS712 20A
Hi Jorgen.
I have modified the component to include both Bidirectional and Unidirectional Current Directionality.
I have also added a voltage offset option to deal with different component tolerances.
Finally, have added a custom selection so you can use a component that is not on the list.
It allows you to set high and low currents, offset, and sensitivity.
The component will be pushed onto the update system as soon as possible.
If you would like to try the component before the updates are pushed.
Browse to this location using file explorer, it's hidden by default so just paste the link into your address bar.
If you run any component updates, then the components you added will be overwritten with the updated version.
Can you let me know how it goes, please?
C:\ProgramData\MatrixTSL\FlowcodeV9\ComponentsIf Flowcode is already open, then you will need to reload your project for the new components to work
- ACS712_Current_Sensor.fcpx
- (5.55 KiB) Downloaded 119 times
Re: ACS712 20A
Hi Martin!
You are amazing
I am first able to test in real world tomorrow evening or wednesday. As soon I have perform a test, you are first who I tell.
Thank you Martin.
Jorgen
You are amazing
Thank you Martin.
Jorgen
Re: ACS712 20A
Hi Martin!
Just perform a quick test with the ACS758 working perfect now
But no change whatever value I put in the offset, is this only for custom selection ?
Edit; Just have a closer look to the custom selection, yes for that, so nice Martin, look forward to test .
Thank you very much.
Br jorgen
Br jorgen
