Had a simialr porblem before i try the fix i used then and it didnt work, I believe its a problem with my compiler settings, I've attached both code and compiler bug report files.
Any Help is appreciated
Have Error code with my code when compiling
803772
- Has thanked: 1 time
- tester1, water pipe.fcfx
- (13.28 KiB) Downloaded 95 times
- tester1, water pipe.msg.txt
- (2.49 KiB) Downloaded 105 times
- Has thanked: 441 times
- Been thanked: 656 times
Re: Have Error code with my code when compiling
The problem is your filename.
You have a comma in it which is not allowed.
Save your file as Tester1_Water_Pipe or such like and it should then compile.
