Code works in Simulation but not in hardware
Has thanked: 1 time
Post by 803772 »
I am stupid and dont know how to compile files correctly. I have a file that works and compiles correctly so i believe it might be a problem with my properties for the motor
motor work.msg.txt
(3.19 KiB) Downloaded 79 times
motor work.fcfx
(11.69 KiB) Downloaded 90 times
Has thanked: 392 times
Been thanked: 603 times
Re: Code works in Simulation but not in hardware
In your file you have set the enable pin to the same pin used as motor "Pin A". You will need to change this to another free pin.
Have you looked at the component WiKi yet? It gives an example of how to use the motor component.
https://www.flowcode.co.uk/wiki/index.p ... C_Motor_()
