Compile problem with ESP WIFI KIT 32
wayne_millard
Has thanked: 1 time
Been thanked: 9 times
Post by wayne_millard »
Hi Everyone
Can someone tell me why this will not compile? :x
Thanks,
Wayne M
RTC_ESP32.fcfx
(20.4 KiB) Downloaded 630 times
RGV250
Has thanked: 41 times
Been thanked: 42 times
Re: Compile problem with ESP WIFI KIT 32
Post by RGV250 »
Can you post the errors it shows, unfortunately I cannot compile it as I only have V9 so no gLCD component.
Bob
Has thanked: 427 times
Been thanked: 647 times
It compiles to Hex OK for me, but as I don't have that module I can't check any further. If you could post the errors as Bob suggested then maybe we can help further.
Also it may help to inform if it is just this chart you are having issues with and any other relevant info.
wayne_millard
Has thanked: 1 time
To all,
This is what is see.
Checking Python dependencies...
Running ninja in directory c:\work\rtc_esp32\build
Executing "ninja all"...
ninja failed with exit code 1
Build Failed
Autoclose turned off
FINISHED
Wayne M
RGV250
Post by RGV250 »
I did a quick google and found this https://www.esp32.com/viewtopic.php?f=2&t=30853
Bob
Has thanked: 154 times
Been thanked: 887 times
Post by mnfisher »
What version FC and espressif tools are you using?
It compiles under v10 (using espressif v5.0) - but only after a doing an update (help->library updates) which updated several of the esp files
Has thanked: 222 times
Been thanked: 240 times
Hi Wayne, Hi Martin, Hi Bob
I downloaded your program and somehow I already had an rtc_esp32. So my computer renamed it to RTC_ESP32 (1).fcfx
This gives problems when compiling to hex.
Running cmake in directory c:\users\kfs-forschung\downloads\rtc_esp32_(1)\build
Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 -DIDF_TARGET=esp32 -DCCACHE_ENABLE=1 c:\users\kfs-forschung\downloads\rtc_esp32_(1)"...
Build Failed
Then I changed the file to RTC_ESP32n.fcfx.
and it compiles to hex without problems.
I changed the file to RTC_ESP32 1.fcfx
I changed the file to RTC_ESP32(1).fcfx
and error! again
In my earlier post in which it compiled to Hex for me, I was running FCv10 using IDF4.2 and Python 3.8. When opening in FCv9 I'm informed the project was built using a newer version etc (so I guess v10) but still compiled to Hex OK. So between replies it has compiled on known working versions / installs.
As Martin suggests, it would be helpful to know Wayne's FC version and if the database has been fully updated, and which "toolchain" he's using. In addition it would be helpful to know if he's ever successfully compiled.
I'll make sure never to use parenthesis as per Stefan's post :)
wayne_millard
Has thanked: 1 time
Yes fully upto date on line libraries and software I'm running flowcode 10 on a Windows 11 pc.
What ESP toolchain are you using, and has it ever worked for you?
