Hello!
I have a question. I want to transmit the string "AD1CB4E1AA2EDDAF" through the serial communication pin (RC6) of the PIC16F877A using a transmitter RF module and receive the string using a receiver RF module connected to the pin (RC7) of the second PIC16F877A, and as confirmation that the string was received to light a led. How should I proceed? I am attaching the two flowcharts.
Thank you very much.
send/receive string
samtin
- Has thanked: 12 times
- Been thanked: 6 times
send/receive string
- rx.fcfx
- (15.72 KiB) Downloaded 593 times
- (view online)
- tx.fcfx
- (12 KiB) Downloaded 526 times
- (view online)
- Has thanked: 478 times
- Been thanked: 712 times
- Has thanked: 792 times
- Been thanked: 850 times
Re: send/receive string
Hi.
Just one additional thing to chipfryer27's helpful post.
When converting a Float to a string, you can state how many decimal places to round to.
Take a look at this Wiki entry
Hello everybody
I did not get the expected results, the LED does not light up. I did a test by connecting the development boards with wires and it works like that, but in RF it doesn't work. If the data is received in RF, shouldn't the received string be found in the "receiver" variable?
Do you have a datasheet for the RF modules? Do they perhaps need some configuration or to be paired?
Can you post your Flowcode file?
Stange it works over wire but not RF which does suggest module related.
Do you have a USB-TTL serial converter? If so run a terminal program and see what is happening at the module Tx/Rx pins.
I don't have HC-05 modules, nor USB-TTL serial converter, I only have RF 433MHz modules that work, for tx a pin in data and for rx a pin out data.
Sorry, I forgot the flowchart.
- rx.fcfx
- (17.39 KiB) Downloaded 574 times
- (view online)
