PIC32 USB CDC No function after last update
SpeedPIC32
Has thanked: 49 times
Been thanked: 20 times
Flowcode v10 PIC32 USB CDC No function after last update
Post by SpeedPIC32 »
Hello all,
something went wrong with the last USB update.
In FC9 and FC10 the USB interface is no longer recognised by my computer. Please make the old version available as soon as possible.
there is no error message when compiling. :evil:
Greetings SpeedPic32
Has thanked: 311 times
Been thanked: 479 times
Re: PIC32 USB CDC No function after last update
Do you mean the last update to the USB component? If so, you can revert to an older component using the "Help...Library Updates" screen using the following steps:
  1. Open your project in Flowcode
  2. Open "Help...Library Updates"
  3. Tick "Show up-to-date files"
  4. Tick the file you want to change
  5. Click on that row in the "New Revision" column and select the older version you require
  6. Click "Download" to revert that file to the earlier version
  7. Restart Flowcode and try your project again
If your project compiles with the reverted component, then please post the following files as this will help us determine what the problem is:
  • Your *.fcfx project file
  • The generated C code file for the working project
  • The generated C code file for the project that is not working
Also please tell us which version of the component worked for you.
SpeedPIC32
Flowcode v10 Re: PIC32 USB CDC No function after last update
hello steve.
the compilation works perfectly. nevertheless, the interface cannot be found.
fc9 and fc10 compile without errors and the rs232 port is no longer there.
greetings SpeedPic32
test usb cdc06092023 fc9.fcfx
(8.28 KiB) Downloaded 768 times
USBCDC FC9 .txt
(44.85 KiB) Downloaded 571 times
Has thanked: 795 times
Been thanked: 858 times
I believe this to be a Windows security issue as the generated driver is not signed.
Therefore, from Windows 10 onwards, unsigned drivers won't be loaded.
There are workarounds for this.
For example, loading Windows in safe mode:
https://www.driversupport.com/knowledge ... ut%20issue.
SpeedPIC32
Hello medelec35
I don't think so. I have a hex file that runs.
I was able to compile up to the update and had no problem with it. the special thing is that the update is for FC10 and FC9 is also affected by it.
SpeedPIC32
hello together
windows shows an error in the USB device descriptor code 43
Greeting SpeedPic32
SpeedPIC32
hello,
where can I get a driver that works?
I have tried the error under win 10 code 43
without success.
I need this driver urgently.
Who can help?
Is it possible to use the driver from Harmony 3?
HI,
have you looked at this wiki page?
SpeedPIC32 wrote: ↑
Wed Sep 06, 2023 7:00 am
Sorry, but I am not sure exactly what you mean. What specific update are you referring to?
SpeedPIC32
Error hello Steve-Matrix,
there was an update Pic32 USB files about a week ago.
Before the update I could program my Flip Clickboard with a PIC32MZ2048EFH100 with USB CDC. it was enough to select under comms: USB CDC and call the initialisation and the PC with win10 showed the USB Serial interface. now this always comes up in FC 9 and 10.
I installed the update with FC 10. The possibility to play it back does not work.
FC9 and 10 access the same batch file. is it possible that an error has occurred? where can I load the file for exchange? is there a possibility to work with Harmony 3?
