pic12f1571 no PWM
baz_w
Flowcode v9 pic12f1571 no PWM
Post by baz_w »
No pwm output on any channel, I have tried both 8 and 12 bit set duty cycle on all 3 channels but to no avail, Am running at 16MHz clock with a 16KHz PWM frequency. Have tried all combinations of OSCCON system select bits. Analog inputs work OK. Did have a problem with having OSCCON as the first statement in flowcode , the chip would only run at default frequency (500KHz) but putting an output statement at the beginning solved that.
Has thanked: 551 times
Been thanked: 735 times
Re: pic12f1571 no PWM
Please can you post your Flowcode project file and we will investigate for you.
baz_w
Post by baz_w »
Hi Ben, forgot to mention that all is OK in simulation but will not work when programmed in to a chip, have tried 3 chips all with the same problem. sorry for the delay in replying but been away.
Barry
1571 TEST.fcfx
(13.22 KiB) Downloaded 352 times
