Ilidisplay after latest update!
Has thanked: 843 times
Been thanked: 205 times
Flowcode v10 Ilidisplay after latest update!
Post by jgu1 »
Again, after update this afternoon the ILI9341, ili9488 and the ST7796 with ESP32 not working again :evil:
Jorgen
Has thanked: 725 times
Been thanked: 783 times
Re: Ilidisplay after latest update!
Hello Jorgen.
We are really sorry, that the latest update breaks things, but they are done for a very good reason.
The updates will cause pins to change.
Can you please change the component pins back to where they were, prior to today's update.
Post by jgu1 »
Hi Martin!
I got a chock :) I have some project with these display and device I still working on, and suddently not working and every time there are a new update I check to see if it still is possible to compile :roll:
I change the pin, and on the "highspeed mode" they work again, but I have my most inportan project I made before Ben speed up these display where I use other pinnumber, this will not compile even after have change the pin as before update.
To be sure I have a PC where I still not have perform the latest update I compare all the pin. Please have look.
NewSun.msg.txt
(48.31 KiB) Downloaded 482 times
NewSun.fcfx
(189.38 KiB) Downloaded 492 times
Has thanked: 618 times
Been thanked: 818 times
Many apologies for that, hopefully now fixed for you.
Post by jgu1 »
Hi Ben & Martin!
All display work again, thank you to both of you for fast action ;)
Have a nice weekend.
Jorgen
