The hardware does not run after downloading to the chip using port programming
niedian
Has thanked: 3 times
Been thanked: 5 times
Flowcode v10 The hardware does not run after downloading to the chip using port programming
Post by niedian »
I use esp32_ WROOM_ 32 controls 4 LEDs, with control pins in the flowchart. After downloading to the chip, the hardware runs normally. However, if the port is controlled in the flowchart, the hardware does not run and the LED does not light up after downloading to the chip. Please help me take a look! Thank you!
LED_PORT.fcfx
(10.45 KiB) Downloaded 1019 times
LED_Pin.fcfx
(10.45 KiB) Downloaded 1102 times
