DirkB
Posts: 100 http://meble-kuchenne.info.pl
Has thanked: 1 time
Been thanked: 4 times
Post
by DirkB » Sat Nov 11, 2023 12:12 pm
there has been an update to the PWM. After the update, the compiler returns an error. The PWM no longer works. My chip is the 16F1825. Everything worked fine until yesterday.
Here is the error message.
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_PWM.c:88:2: error: (192) undefined identifier "MX_PWM_TRIS_11"
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_PWM.c:88:27: error: (192) undefined identifier "MX_PWM_PIN_11"
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_PWM.c:88:43: error: (192) undefined identifier "MX_PWM_PORT_11"
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_PWM.c:340:1: error: (192) undefined identifier "MX_PWM_TRIS_11"
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_PWM.c:340:25: error: (192) undefined identifier "MX_PWM_PIN_11"
PWM no function after update
Dirk
Posts: 1814 Joined: Thu Dec 03, 2020 10:57 am
Has thanked: 404 times
Been thanked: 624 times
Post
by chipfryer27 » Sat Nov 11, 2023 12:24 pm
Can you attach your chart?
Also, after an update components sometimes "default" to initial pin values. It's worth checking that your pin assignments are still valid.
DirkB
Posts: 100 Joined: Thu Dec 10, 2020 3:55 pm
Has thanked: 1 time
Post
by DirkB » Fri Nov 17, 2023 3:17 pm
of course, I always create a new project with this
component to rule out other errors. The same result.
DirkB
Has thanked: 1 time
Post
by DirkB » Fri Nov 24, 2023 6:15 pm
After the update to PWM V7 the PWM works. According to the data sheet,
the PIC18F14K22 has up to 4 PWM outputs. How can I set these?
Dirk
