Project does not save port pins
RGV250
Has thanked: 46 times
Been thanked: 48 times
Post by RGV250 »
The APA102 demo project (and others I have saved from it) do not save the port pins. I set the clock pin to G2 and MOSI to G25 and all works fine. When I re open the project they have reverted back to G10 & G11.
Bob
Has thanked: 795 times
Been thanked: 858 times
Flowcode v10 Re: Project does not save port pins
Hi Bob.
Hopefully, this will sort your issue out.
C:\ProgramData\MatrixTSL\FlowcodeV10\Components
Place the attached component.
If you run any component updates, then the component you added will be overwritten, so it will stop working again.
LED_APA102C.fcpx
(13.28 KiB) Downloaded 255 times
