Uno with RFID-RC522!
Has thanked: 839 times
Been thanked: 205 times
Post by jgu1 »
Hi!
I have tested this acces kontrol board and want to use it in a project. I have taken the examble from Wiki and change the device to an Arduino uno,
working perfect :D But how do I add more tags to match, any advice, please? :roll:
Thank´s in advance.
Jorgen
MFRC522_UID_UnoTest.fcfx
(19.11 KiB) Downloaded 466 times
Has thanked: 292 times
Been thanked: 458 times
Re: Uno with RFID-RC522!
The single tag to check in this example is defined as an array of 4 bytes - UID[4]. If you wanted to check multiple tags, then use a multidimensional array - e.g. UIDS[8][4] for 8 separate tags. Once you have read the tag, you would need to loop through the comparison multiple times for each tag (and each comparison involves a loop of 4 for each byte in the tag).
Post by jgu1 »
Thank you Steve, I will try to see if I am able to do it. :D
Jorgen
