esp compile error
noovas
esp compile error
Post by noovas »
I am new with Flowcode 10 (free version). I have experience with Flowcode 6 but this was long time ago.....
So, when I try to compile to target I have this error:
FAILED: esp-idf/main/CMakeFiles/__idf_main.dir/esp-project.c.obj
what I have found till now is if I have even just one component macro I receive this error.
Maybe I am doing something wrong or I should install something additional, or maybe component macros are not for the free version?
I appreciate any help.
thanks
Python 3.7.3
git version 2.21.0.windows.1
ESP toolchain found at "C:\Users\User\Desktop\esp-idf\"
Has thanked: 704 times
Been thanked: 768 times
Re: esp compile error
Can you post your Project name.fcfx project file and Project name.msg.txt fie
noovas
Post by noovas »
medelec35 wrote:
Tue Jan 16, 2024 3:31 pm
Hello, medelec35
project name is: Flowcode2.fcfx
attached file is the .txt file
Flowcode2.msg.txt
(175.23 KiB) Downloaded 583 times
Cam you post your .fcfx project file, please.
noovas
Post by noovas »
inside there is just one component macro (in my case PWM enable)
Flowcode2.fcfx
(8.56 KiB) Downloaded 710 times
After selecting PWM:0 Timer:0 Pin:A from the PWM Timer properties, your project compiled for me.
Can you give that a try and attach the latest .msg.txt if still not compiling for you.
At least now compiling will be a lot quicker as it won't be the first time of compiling.
noovas wrote:
Tue Jan 16, 2024 3:05 pm
Flowcode 10 is free for makers and hobbyists.
That means all the components are now free and there are no code size restrictions, unlike all the other versions of Flowcode.
noovas
Post by noovas »
I have tried many times with different projects, different versions of Python. Few times I reinstall and the ESP toolchain, but without success.
If the project contains output, loops and delays it compiles without problem (making a led flash is not a problem and it uploads ).
here is latest .txt report....
Flowcode2.msg.txt
(30.56 KiB) Downloaded 559 times
Has thanked: 592 times
Been thanked: 780 times
This is the error you're getting.
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ESP\ESP_CAL_PWM.c:48:8: error: no macro name given in #define directive
48 | #define
It looks like you need to go to Help -> Library Updates and get the latest files. Hopefully that should allow you to compile.
noovas
Post by noovas »
Hello BenR and thank you for the help!!!
Actually thank you very much, it is working now!! :D
