Webserver Information not Displaying.
daddytims_tims
Has thanked: 125 times
Been thanked: 13 times
Flowcode v10 Webserver Information not Displaying.
Post by daddytims_tims »
I wrote a small little program. using an Esp32 where I used the Esp32 hardware to Turn on/off 2 separate Motors. @ home which it works.
Now I WANT a 2 Way COMMUNICATION where I can be able to Monitor the STATE of the Pins/Motor in my Webserver, an also Turn them oN/Off on the Webserver when I am Not at home.
I added the webserver component. a set out the values, but it's not been displaying.
Maybe I miss something. or I haven't done something right.
I need some help please.
I attached the program
Esp32_Webserver_Push_Button.fcfx
(29.65 KiB) Downloaded 451 times
Has thanked: 268 times
Been thanked: 432 times
Re: Webserver Information not Displaying.
I've recently made a full worked example using an ESP32 and Flowcode v10's new Web Developer mode, although this is not officially released yet. I've attached the doc and example files in case they help you.
Although the examples are pairs (an embedded one for the ESP32 and a Web Developer one for the web app), you don't necessarily need to use them together and the techniques in the embedded projects may be all you require.
Web Developer and Embedded worked example.pdf
(761.12 KiB) Downloaded 558 times
Project Files.zip
(26.83 KiB) Downloaded 525 times
daddytims_tims
Thanks a lot Steve, I will go through it.
daddytims_tims
Flowcode v10 Re: Webserver Information not Displaying.
I hooked up my BL0058-1 and tested it.
It worked out very well.... THANKS AGAIN!!!
