Hi FC Team,
A) I have been playing with the Pi PICO for a short time and i'm aware some PICO pins are internal but non the less, are in theory readable
GP25 - Pico LED - Is this controllable? Pin A.25 not selectable.
GP24 - USB Detect - Is this readable? Pin A.24 not selectable.
GP29 - VSYS/3 Monitor - Is this readable? Pin A.24 not selectable.
ADC4 is the internal temp Sensor, can this be read?
B) ADC Pins
What is the Best component to read the native ADC pins? using the raw ADC(cal) component?
Thanks, John.
Pi PICO - Reading Internal Pins and ADC pins
jay_dee
- Has thanked: 99 times
- Been thanked: 69 times
- Has thanked: 292 times
- Been thanked: 458 times
Re: Pi PICO - Reading Internal Pins and ADC pins
I'll attempt to answer these backwards.
B) I would use a 2d Potentiometer component to read ADC pins.
A) I don't know, but you should be able to use C code to access these.
For example, if you have a byte variable "x", then you could try the following in a C code icon to read GP24 and write GP25:
There will be a way to use C code directly to access ADC4, but I've not been able to quickly work out a way to do this.
FCV_X = GET_PORT_PIN(A,24);
SET_PORT_PIN(A,25,(FCV_X));-
- Has thanked: 442 times
- Been thanked: 661 times
The Pico quickly grew on me. Really like it.
This post explains how to use the LED and also second core.
viewtopic.php?f=3&t=2065&hilit=pico&start=20
