Flowcode 9 and Microchip\xc8\v2.30 Parameter
SpeedPIC32
Has thanked: 49 times
Been thanked: 20 times
Post by SpeedPIC32 »
can the newest compiler XC8 be integrated in FC9?
I can set the path
I miss the parameters.
The values ​​from old forum posts do not work.
The latest XC32 compiler v2.50 works fine.
Thanks in advance
Has thanked: 724 times
Been thanked: 783 times
Re: Flowcode 9 and Microchip\xc8\v2.30 Parameter
When you download XC8 tool chain from here
It is version 2.10
The settings for the compiler is
Parameters: $(chip) "$(outdir)" "$(target)"
I have questioned if the batch file is correct, so will leave that up to you if you want to modify it or not
On the other forums I posted about updating the compiler here
SpeedPIC32
thank you medelec35
it all works very well.
Thank you for your quick help
With the old compiler I had warnings about the build rate Uart 1. They have now disappeared
I still have a problem with the Uart1 receive interrupt
Pic16F18877 32Mhz RX Pin RC6 TX Pin RC7
Thanks in advance
