Timer interval and Timer - problem
DStoyankov
Has thanked: 5 times
Flowcode v10 Timer interval and Timer - problem
Post by DStoyankov »
Library Timer Interval and Timer not working.
Example with PIC24FJ128DA110 , Timer :
Launching the compiler...
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\PIC16\batchfiles\pic16_C30_comp.bat "C:\Program Files (x86)\Flowcode\Common\Compilers\pic16\" "Flowcode2" "D:\FLOW_PROJECT\simulator_EXECUTIVE\" "24FJ128DA110"
D:\FLOW_PROJECT\simulator_EXECUTIVE>REM CRC: 54CD51B8F484283E91B3AD9DE6F4F50C418D34178E0D3D0BD2659E1DA9D69F58D3529BB9468CFC85641793EB31F94A5F16CBA8333F125C7188ED8742865A1BBCF23BFF3064C25A11BAFA61B701B8D046E2B847C06A341BA1A924146F47BB51131AFA1B63045FF8EFD8DA408700E5719BD2897C22C80F0B985EDF8CE67A1404D62B8878703E3665631EAF018A0B6018ACC8FF364DB19D83FB389861B26F27604A1F36255EB2E4245255911F067119BEF7D5F89C133B93261A29D848A5DAD12E38FF9E5CFBC45304482C3050DA273BE4EEDBE038345E976FF7F0C03E6C1723E33C3CC5736D0D2DAB0D0DA6C43ED30373AA133F965729382C18
D:\FLOW_PROJECT\simulator_EXECUTIVE>REM REVISION: 2.0
D:\FLOW_PROJECT\simulator_EXECUTIVE>REM GUID: 7821ABE5-9E21-4744-81B7-3FF600B75DB7
D:\FLOW_PROJECT\simulator_EXECUTIVE>REM DATE: 25\03\2024
D:\FLOW_PROJECT\simulator_EXECUTIVE>REM DIR: FCD\PIC16\batchfiles\pic16_C30_comp.bat
D:\FLOW_PROJECT\simulator_EXECUTIVE>xc16-gcc -c -mcpu="24FJ128DA110" -omf=coff -funsigned-char -fno-short-double -Os -I"C:\Program Files (x86)\Flowcode\Common\Compilers\pic16\support\h" -I"C:\Program Files (x86)\Flowcode\Common\Compilers\pic16\" -I"C:\Program Files (x86)\Flowcode\Common\Compilers\pic16\batchfiles\" -std=gnu99 "Flowcode2".c -o "Flowcode2".o
Options have been disabled due to restricted license
Visit http://www.microchip.com/ to purchase a new key.
Flowcode2.c: In function 'main':
Flowcode2.c:1785:2: warning: 'return' with a value, in function returning void
Flowcode2.c: In function '_T1Interrupt':
Flowcode2.c:1822:5: error: 'FCV_00a91_TimedInterval1__INTCOUNT' undeclared (first use in this function)
Flowcode2.c:1822:5: note: each undeclared identifier is reported only once for each function it appears in
Flowcode2.c:1830:11: error: 'TimerInterval_1_CountRegLow' undeclared (first use in this function)
Flowcode2.c:1830:41: error: 'TimerInterval_1_SubPeriod' undeclared (first use in this function)
Flowcode2.c:1926:11: warning: implicit declaration of function 'TimerInterval_1_Macro'
Error returned from [xc16-gcc.exe]
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\PIC16\batchfiles\pic16_C30_comp.bat reported error code 0x1
Autoclose turned off
FINISHED
Example with PIC24FJ128DA110 , Timer Interval:
Using <PICkit2 PK2CMD External Power> inbuilt settings for compiler
Flowcode2.c:2856:2: warning: 'return' with a value, in function returning void
Flowcode2.c: At top level:
Flowcode2.c:2893:5: error: expected '=', ',', ';', 'asm' or '__attribute__' at end of input
Example with ARDUINO MEGA 2560 R3 , Timer Interval
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\AVR\batchfiles\avra.bat "C:\Program Files (x86)\Flowcode\Common\Compilers\avrv5\" atmega2560 "D:\FLOW_PROJECT\simulator_EXECUTIVE\Flowcode2.elf" "D:\FLOW_PROJECT\simulator_EXECUTIVE\Flowcode2.c" "D:\FLOW_PROJECT\simulator_EXECUTIVE\Flowcode2.lst"
D:\FLOW_PROJECT\simulator_EXECUTIVE>REM CRC: EA277D0C7EF9B4E537B79187D0BE7A25FA6080B4B01BE48BAF713429E4B690411241251B4A05C2B5828F4452C9F7348705C640EF477B79E0C7881D2E5EEC9BD69A0D46BD3B6AACB92DE4D84759EBB5079CA9DA2D2BBCDAE2A4D1C56CD1580BF5A24465F11D9C3B2DBA3F4E37F13004EE3637760F1F0B7DA0CC623CD30E3C7D6BAB4C3FE6151D92B8EC0ADD55E96639DAC02472BDE3806EF43AE3A028BD32A5DAE68BB191DA97CB6883A66D3C41849952BB2DD264AF32733E2C3050DA273BE4EE1FA30153290F2FAFBD2259D77AD477809E9C4D76400384BA5D2E1919BC6D834D57C406BC4A49D3F1
D:\FLOW_PROJECT\simulator_EXECUTIVE>REM REVISION: 1.0
D:\FLOW_PROJECT\simulator_EXECUTIVE>REM GUID: EA0828B2-5C70-41A5-8C54-F359DD5CC88B
D:\FLOW_PROJECT\simulator_EXECUTIVE>REM DATE: 08\08\2022
D:\FLOW_PROJECT\simulator_EXECUTIVE>REM DIR: FCD\AVR\batchfiles\avra.bat
D:\FLOW_PROJECT\simulator_EXECUTIVE>"C:\Program Files (x86)\Flowcode\Common\Compilers\avrv5\bin\avr-gcc.exe" -mmcu=atmega2560 -Os -ffunction-sections -fdata-sections -funsigned-char -o "D:\FLOW_PROJECT\simulator_EXECUTIVE\Flowcode2.elf" "D:\FLOW_PROJECT\simulator_EXECUTIVE\Flowcode2.c" -lm -Wl,-gc-sections
D:\FLOW_PROJECT\simulator_EXECUTIVE\Flowcode2.c: In function '__vector_20':
D:\FLOW_PROJECT\simulator_EXECUTIVE\Flowcode2.c:1823:5: error: 'FCV_00a91_TimedInterval1__INTCOUNT' undeclared (first use in this function)
// } else {
D:\FLOW_PROJECT\simulator_EXECUTIVE\Flowcode2.c:1823:5: note: each undeclared identifier is reported only once for each function it appears in
D:\FLOW_PROJECT\simulator_EXECUTIVE\Flowcode2.c:1831:11: error: 'TimerInterval_1_CountRegLow' undeclared (first use in this function)
TimerInterval_3_CountRegLow = TimerInterval_3_SubPeriod;
D:\FLOW_PROJECT\simulator_EXECUTIVE\Flowcode2.c:1831:41: error: 'TimerInterval_1_SubPeriod' undeclared (first use in this function)
D:\FLOW_PROJECT\simulator_EXECUTIVE\Flowcode2.c:1835:13: error: 'TimerInterval_1_CountRegHigh' undeclared (first use in this function)
TimerInterval_3_CountRegHigh = TimerInterval_3_SubPeriod >> 8;
D:\FLOW_PROJECT\simulator_EXECUTIVE\Flowcode2.c:1927:11: warning: implicit declaration of function 'TimerInterval_1_Macro' [-Wimplicit-function-declaration]
#if (1 == 1)
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\AVR\batchfiles\avra.bat reported error code 0x1
D:\FLOW_PROJECT\simulator_EXECUTIVE\Flowcode2.c:2894:5: error: expected '=', ',', ';', 'asm' or '__attribute__' at end of input
DStoyankov
Flowcode v10 Timer and Timer interval not working
Library Timer and Timer interval not working.
Tested: Arduino Mega 2560 R3 and PIC24F128
Has thanked: 607 times
Been thanked: 803 times
Re: Timer interval and Timer - problem
I can't replicate the issue, please can you check you have the latest updates using Help -> Library updates.
If you're still getting the issues then please attach your .fcfx project file and also your .msg.txt compiler messages files.
DStoyankov
The problem is not solved.
Target folder: D:\FLOW_PROJECT\simulator_EXECUTIVE
Source name: D:\FLOW_PROJECT\simulator_EXECUTIVE\Flowcode2.fcfx
Title:
Description:
Device: ARD.ATMEGA.ATMEGA2560
Generated by: Flowcode v10.1.0.38
Date: Friday, April 26, 2024 14:06:25
Users: 1
Registered to: DStoyankov (91709826)
Licence key: MAC8WB
https://www.flowcode.co.uk
FINISHED
Flowcode2.msg.txt
(2.08 KiB) Downloaded 856 times
Flowcode2.fcfx
(14.9 KiB) Downloaded 865 times
As you're not calling any of the component macros that can cause problems in the code generation. Try calling some of the component functions and let us know how you're getting on.
There also seems to be a bug with timers over timer 2, looking into this now.
Hopefully this is now resolved with the latest library updates.
DStoyankov
Only Timer component, Timer = Timer 1 - not working
I mean the timer peripheral selected in the timer component properties. Seems to be fixed now with the latest library updates. Timers 3, 4, 5 now working.
DStoyankov
ARDUINO MEGA 2560 R3 - Update library and not working Timer library.
Flowcode3.msg.txt
(2.08 KiB) Downloaded 1034 times
Flowcode3.fcfx
(8.52 KiB) Downloaded 933 times
DStoyankov
PIC24FJ1024GA606 - Timer library not working
Flowcode2.msg.txt
(2.36 KiB) Downloaded 1035 times
Flowcode2.fcfx
(8.72 KiB) Downloaded 956 times
