ESP32 Compilation Warnings
Has thanked: 177 times
Been thanked: 1016 times
Post by mnfisher »
A little tip to make life easier.
The output from the esp32 compiler is a 'little' verbose. It is possible to turn off some of the warnings.
In your project directory/main
Edit CMakeLists.txt
At the end of the file add:
target_compile_options(${COMPONENT_LIB} PRIVATE -Wno-unused-variable)
target_compile_options(${COMPONENT_LIB} PRIVATE -Wno-unused-function)
target_compile_options(${COMPONENT_LIB} PRIVATE -Wno-int-conversion)
This will turn off unused variable and function warnings as well as conversion between integer types. Obviously you should aim to tidy up the code that gives these messages - but it makes spotting the error 'needle' easier in the early project haystack...
Other warnings can be disabled using similar syntax....
Has thanked: 634 times
Been thanked: 839 times
Re: ESP32 Compilation Warnings
Thanks Martin,
Just getting round to this and I've updated the default file so that the following applies when compiling a new project.
target_compile_options(${COMPONENT_LIB} PRIVATE -Wno-cpp)
target_compile_options(${COMPONENT_LIB} PRIVATE -Wno-unused-but-set-variable)
target_compile_options(${COMPONENT_LIB} PRIVATE -Wno-incompatible-pointer-types)
target_compile_options(${COMPONENT_LIB} PRIVATE -Wno-discarded-qualifiers)
I've also popped this line in there should you want to disable to treat certain warnings as errors, e.g. return variable not set or variable not initialised etc.
#You can disable all warnings as errors by uncommenting the line below.
#target_compile_options(${COMPONENT_LIB} PRIVATE -Wno-error)
Annoyingly I'd only seen your post once I'd found out and applied the info myself! doh!
Post by mnfisher »
Thanks Ben,
It makes for a much nicer working environment - I mentioned it again in the notes about lvgl - where there are reams of warnings...
I've got a copy of LVGL compiling now too so looking forward to having a play with it and seeing what we can do with it going forward.
Post by mnfisher »
It's good isn't it :-)
Especially with EEZ (or SquareLine) Studio
