Login issues with this forum
Has thanked: 306 times
Been thanked: 471 times
To login to this forum, you will need to use the same username and password as your Flowcode account.
If you want to change your password, then login to the main Flowcode website (e.g. by using this link) and click the "change password" link near the bottom of that page. If you change your password, the new password will be used to access the website, this forum and to use Flowcode itself.
If you have forgotten your password, then there is a link to reset your password on the website login page:
https://www.flowcode.co.uk/accounts/login/
There is also a link to be sent your username to your email address if you have forgotten it.
If your username is not recognised when logging into this forum, make sure you first log in to the flowcode.co.uk site using the same username as this will create your forum account.
If you can successfully log into this website but continue to have a problem logging into the forums (e.g. due to the "You have exceeded the maximum allowed number of login attempts" message), please contact us via the contact page with details of the issue and you username:
https://www.flowcode.co.uk/contact/
