Atmega128 Compile warnings
Alan_37
Has thanked: 57 times
Been thanked: 28 times
Post by Alan_37 »
Getting a lot of warnings when compiling to Hex, The code works OK
Any idea why ?
ATmega128A.fcfx
(25.9 KiB) Downloaded 312 times
ATmega128A.msg.txt
(20.36 KiB) Downloaded 322 times
Has thanked: 616 times
Been thanked: 815 times
Re: Atmega128 Compile warnings
We mark variables as volatile so that they work correctly when manipulated inside an interrupt. Some functions do not accept volatile variables so the volatile cast is simply removed and hence the warning. Should be safe to ignore. I'll see if it's something we can potentially hide from the compiler output.
Alan_37
Post by Alan_37 »
Hi BenR
Thanks for your reply
where sould I put the -w flag to ignore warnings, the problem is a lot of warnings
mixing with errors and it's making it difficult to spot and fix the errors.
Alan_37
Post by Alan_37 »
OK Found it
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\AVR\batchfiles\avra.bat
LIne 13 : add -w after -Os
"%MX_COMPILER%bin\avr-gcc.exe" -mmcu=%MX_CHIP% -Os -w -ffunction-sections -fdata-sections -funsigned-char -o %MX_ELF% %MX_SOURCE% -lm -Wl,-gc-sections
Now compiles much faster :)
