Just experimenting with getting an ideal font and contrast for a project and I am unable to find a font larger than 14 that will compile.
Have i got a setting wrong that is causing this issue, what does compile displays fine on the GLCD.
Ian
GLCD 1306 Font compile errors
ianjoh
- V10_1306_display.fcfx
- (12.51 KiB) Downloaded 322 times
- (view online)
- Has thanked: 637 times
- Been thanked: 847 times
Re: GLCD 1306 Font compile errors
Hello Ian,
I imagine you're running out of ROM with a larger font, they tend to eat memory.
If you want a big font then one way would be to create your own with a reduced character set to save on the amount of ROM required.
Details on how to do this are available here.
https://www.flowcode.co.uk/wiki/index.p ... l_Library)
Another way would be to use the SetFontScaler component macro to scale up a smaller font.
I also see that you have 4 fonts enabled in your project but currently you're only using 2 of them. Removing the fonts you're not using will help to save a load of ROM space.
