hi to all
need help to setup flowcode 10 for compile esp 32
log
Target folder: C:\copy\esp32 test
Source name: C:\copy\esp32 test\Flowcode1.fcfx
Title:
Description:
Device: ESP.ESP32.ESP32_WROOM_32
Generated by: Flowcode v10.1.2.40
Date: Saturday, December 21, 2024 23:53:21
Users: 1
Registered to: pivbmw (FREE_VERSION)
Licence key: DF7JCQ
NOT FOR COMMERCIAL USE
https://www.flowcode.co.uk
Using <> user settings for compiler
Launching the compiler...
C:\FC_ESP\esp-tools\idf_cmd_init.bat ESP32_WROOM_32
Setting PYTHONNOUSERSITE, was not set[/b][/b]
Using Python in C:\copy\esp32 test\
'null' is not recognized as an internal or external command,
operable program or batch file.
Using Git in C:\FC_ESP\esp-tools\Espressif\tools\idf-git\2.44.0\cmd\
git version 2.44.0.windows.1
Using <> user settings for linker
C:\Program Files (x86)\Flowcode v10\tools\DoNothing\DoNothing.exe
FINISHED
what i do wrong ?
please help
instaled all according guide
esp 32 compile error
pivbmw
- Has thanked: 1 time
Re: esp 32 compile error
reinstaled all
and now have this error
Title:
Description:
Date: Sunday, December 22, 2024 20:15:41
Users: 1
Licence key: DF7JCQ
FINISHED
help to set up for compile to esp
thanks
Title:
Description:
Users: 1
Licence key: DF7JCQ
FINISHED
thanks
- Has thanked: 778 times
- Been thanked: 839 times
Did you download the toolchain from here?
Have you updated your component database?
Help > Library Updates..
Change Files in-use to Full database
Click Yes for the warning for this might take a long time
Then click on Download.
You need to refresh your project (File > Reload)
Then try to compile again.
If still not working can you attach the .msg.txt file.
If you look at File > Global Settings... > Locations tab
Check the ESP: path matches the path the ESP toolchain was installed, e.g. C:\FC_ESP
