SRF Receiver!
Has thanked: 831 times
Been thanked: 204 times
SRF Receiver!
Post by jgu1 »
Hi all!
I am working with some HC12 tranceivere (UART) together with the SRF component in FC. Working perfect. At the moment I use String compare, if incomming data is equal then write/update the display. I see it is only possible to send/receive String and Char.
Is it possible to write in the display "only" if new string is received without comparering, first update display when new data is incomming? Please :D
Thank´s in advance
Jorgen
RX.fcfx
(12.66 KiB) Downloaded 205 times
Has thanked: 715 times
Been thanked: 775 times
Re: SRF Receiver!
Hi Jorgen.
What about using the circular buffer?
Then you can do what you want with the data, e.g., display all within the buffer, or look for a keyword etc.
The buffer along with examples can be found on the Wiki here & here
Re: SRF Receiver!
Post by jgu1 »
Many many thanks for the tip Martin, but in the meantime I have found another solution. I will definitely look into your suggestions :idea: .
Last thing, is there a reason why we can only send and receive "string and Char# and not number, in the SRFM component without having to convert from number to String and back again?
And yes, I could use the Uart component ;)
Br Jorgen
Re: SRF Receiver!
You're welcome.
I'm glad you found a solution, well done.
jgu1 wrote:
Tue Jan 28, 2025 12:28 pm
I will ask the member of staff who created the component and let you know.
You could but won't have the Sleep and Wake functions available.
Re: SRF Receiver!
Post by jgu1 »
Perfect Martin :D ;)
Re: SRF Receiver!
Hi Jorgen.
I have added some extra functions to the SRF component to make life easier for you and anyone else who wishes to use it.
If you would like to try it out before pushing to component updates.
%ProgramData%\MatrixTSL\FlowcodeV10\Components
Place the attached component.
SRFModuleWirelessThings.fcpx
(7.3 KiB) Downloaded 195 times
Re: SRF Receiver!
Post by jgu1 »
Hi Martin!
Working :D
The new parameters work perfectly Martin. Now my project can be more simple. Hurry up to push the updated component to the world :lol: .
Many thanks again :)
For others who working with wireless, I can recommend the HC12 module, easy and powerful.
Br Jorgen
Re: SRF Receiver!
You're welcome and thanks for the update Jorgen.
I'm glad the updated component as helped.
It will be pushed on the library database as soon as possible.
Re: SRF Receiver!
hi Jorgen,
the SRF component has now been push onto the components database.
Re: SRF Receiver!
Post by jgu1 »
Perfect, thank´s :D
