ESP32 Bluetooth update please?
MJU20
Has thanked: 105 times
Been thanked: 76 times
Flowcode v10 ESP32 Bluetooth update please?
Post by MJU20 »
I've been watching the discussion about the ESP32 bluetooth component (like: viewtopic.php?p=17368&hilit=bluetooth#p17368 and viewtopic.php?p=4466#p4466 ) and so on.
But what is the latest news on this component?
I have found this dir: C:\Espressif\frameworks\esp-idf-v5.3\mtxesp32s_sdkconfig and know from the past how to edit the menuconfig.bat
But what do I need to edit to get the Bluetooth on my ESP32_Wroom32 working?
I'm using the ESP32 bluetooth example from the Wikipage: https://www.flowcode.co.uk/wiki/index.p ... (Wireless) but this doesn't show the device on my computer or smartphone.
All I want to do right now is to connect a ESP32_Wroom32 with my smartphone and use a serial terminal to send data to the ESP32 and show this on the COM port.
In my idea the ESP should be visible as a device on my smartphone, I could connect to it (without access codes or so on) and use the terminal to send data?
Could someone please guide me through the steps that I need??
Has thanked: 245 times
Been thanked: 256 times
Re: ESP32 Bluetooth update please?
Hi MJU20
That should work with the smartphone.
You have to start the menuconfig.bat
Can You try to start this?
MJU20
Post by MJU20 »
stefan.erni wrote:
Wed Mar 05, 2025 7:57 am
Hi MJU20
Hello Stefan.erni,
I know how to edit the menuconfig.bat, but what settings do I need to edit?
There are many settings for the Bluetooth but I can't see which I need to edit..
Thanks anyway
Hi MJU20
try these settings. Works for me on PC and Android
Classic Bluetooth SPP Protocol
Bluetooth ESP32 SPP 2025_03_06.pdf
(75.67 KiB) Downloaded 266 times
MJU20
Post by MJU20 »
stefan.erni my hero! :-)
You can't imagine how long I was looking to get this feature working.
Thanks!
I hope this can be something other users can use too.
Maybe something that can be put on the Wikipage??
I will post my config too because I have another version of the IDF this could be of some use to other users.
ESP32 bluetooth settings in menuconfig.pdf
(131.23 KiB) Downloaded 234 times
