PIC16F527 and FC10
alanwms
Has thanked: 26 times
Been thanked: 8 times
PIC16F527 and FC10
Post by alanwms »
I see that the 16F527 has internal operational amplifiers. I started a new project to look at this and can't figure out how to use these peripherals. Do we have examples or info on this?
Has thanked: 159 times
Been thanked: 943 times
Re: PIC16F527 and FC10
Post by mnfisher »
You'll need to handle the Analog peripheral setup in C by accessing the relevant registers..
APFCON, CM1CON0/CM2CON0 and OPACON
to:
Enable the op amp
Configure input selection
Enable output routing
Set gain mode
Do you have a specific use in mind?
alanwms
Post by alanwms »
Sure - I want to setup a gain of around 25:1 so I can read a low signal. I'm not proficient writing C code to achieve my goal.
Post by mnfisher »
The documentation (datasheet) verges on the flimsy here - a little on the thin side.....
Apart from table 16-16 showing unity gain mode - there is little info (apart from two bits in OPACON to enable the op-amps)
Looking at the https://ww1.microchip.com/downloads/en/ ... 03280A.pdf document - reveals a lot more control - but the registers mentioned (for example OPA1CON0 don't seem to be present on the PIC16F527.
Do you have any info on it?
Post by mnfisher »
Seems o be more set up as a comparator than an op-amp
Has thanked: 435 times
Been thanked: 651 times
This document is a bit more applicable.
TB3132.pdf
(271.09 KiB) Downloaded 149 times
alanwms
Post by alanwms »
Thanks People!
On the flip side, do you know of better choices for a uP with opamp capacity?
Post by mnfisher »
PIC16F176x or PIC16F177x series might be worth a look...
