Compiler error (SOLVED) internal.c ver 3
celebriums
Has thanked: 25 times
Been thanked: 13 times
Post by celebriums »
Hello Dear Flowcode Family
The software was compiling until today morning, but when I made the updates that came today, I started getting a compilation error. How can I see the library changes you made today?
Everything was working normally until the update.
Sadık
Target folder: C:\ElektronikProjeler\Measure Mechanic\Software
Source name:   C:\ElektronikProjeler\Measure Mechanic\Software\STM32F446RE-V1.06_BATT.fcfx
Title:         MAX32 DEMO
Description:
Device:        ARM.F4.32F446RC
Generated by:  Flowcode v10.1.2.40
Date:          Thursday, April 17, 2025 15:11:12
Users:         1
Registered to: mehmet64 (99154532)
Licence key: 9P152P
https://www.flowcode.co.uk
Launching the compiler...
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\ARM\batch\stm32comp.bat  "STM32F446RE-V1.06_BATT" "C:\ElektronikProjeler\Measure Mechanic\Software\" "32F446xx" "F4" "stm32f.ld" "16000000" "256K" "128K" "C:\Program Files (x86)\Flowcode\Common\Compilers\starm\\"
C:\ElektronikProjeler\Measure Mechanic\Software>REM CRC: 1CECFE3DB3A1BD5169AEA98AD43ADE631EF0A88FFA736FBD84BE44176323F463C8515F4CD0D20BEBDFE06A9E70103FA105C640EF477B79E0C7881D2E5EEC9BD69A0D46BD3B6AACB92DE4D84759EBB5079CA9DA2D2BBCDAE2A4D1C56CD1580BF532505B4DECBAEAC96954F191918D76F05058F85C62E78168DB2117B7F66DFFAB9D4CD39D9819A47B593E224EEC6BA2B1CF18B22880D87C51B667E8BA6E12E6B26FA06B6F4F108199331CCC4A9A2DADF899B5E4011DBDD5202C3050DA273BE4EEBA213254BC0AD6E15FDF8E24F7A49525E37122B659B22A01CA71203F3D907500295E1D946A835C79
C:\ElektronikProjeler\Measure Mechanic\Software>REM REVISION: 1.0
C:\ElektronikProjeler\Measure Mechanic\Software>REM GUID: E810EE73-4726-4718-B23E-B579C5ADBC40
C:\ElektronikProjeler\Measure Mechanic\Software>REM DATE: 08\08\2022
C:\ElektronikProjeler\Measure Mechanic\Software>REM DIR: FCD\ARM\batch\stm32comp.bat
Project STM32F446RE-V1.06_BATT
Device STM32F446xx
C:\ElektronikProjeler\Measure Mechanic\Software>arm-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -Os -DSTM32 -DSTM32F4 -DSTM32F446xx -DUSE_HAL_DRIVER -DHSE_VALUE=16000000 -I"C:\Program Files (x86)\Flowcode\Common\Compilers\starm\\stm32cubeF4\Drivers\CMSIS\Include" -I"C:\Program Files (x86)\Flowcode\Common\Compilers\starm\\stm32cubeF4\Drivers\CMSIS\Device\ST\STM32F4xx\Include" -I"C:\Program Files (x86)\Flowcode\Common\Compilers\starm\\stm32cubeF4\Drivers\STM32F4xx_HAL_Driver\Inc" -I"C:\Program Files (x86)\Flowcode\Common\Compilers\starm\\stm32cubeF4\Drivers\STM32F4xx_HAL_Driver\Inc\Legacy" -I"C:\Program Files (x86)\Flowcode\Common\Compilers\starm\\inc" -fmessage-length=0 -fdata-sections -ffunction-sections -w -c "STM32F446RE-V1.06_BATT.c" -o "STM32F446RE-V1.06_BATT_STM32F446xx_16000000\STM32F446RE-V1.06_BATT.o"
In file included from C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\internals.c:589:0,
                 from C:\ElektronikProjeler\Measure Mechanic\Software\STM32F446RE-V1.06_BATT.h:48,
                 from STM32F446RE-V1.06_BATT.c:20:
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_TypeDefs.c:69:3: error: conflicting types for 'MX_Union32'
 } MX_Union32;
In file included from C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\internals.c:540:0,
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_TypeDefs.c:69:3: note: previous declaration of 'MX_Union32' was here
 } MX_Union32;
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_TypeDefs.c:75:3: error: conflicting types for 'MX_Union16'
 } MX_Union16;
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_TypeDefs.c:75:3: note: previous declaration of 'MX_Union16' was here
 } MX_Union16;
In file included from C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_IO.c:41:0,
                 from C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\internals.c:590,
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_IO.h:75:6: error: conflicting types for 'FC_CAL_Port_Out__x'
 void FC_CAL_Port_Out__x (MX_UINT8* Port, MX_UINT8 OutMask, MX_UINT8 OutValue);
In file included from C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\internals.c:541:0,
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_IO.c:1145:14: note: previous definition of 'FC_CAL_Port_Out__x' was here
  static void FC_CAL_Port_Out__x (GPIO_TypeDef *PORT, uint16_t OutMask, uint16_t OutValue)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_IO.h:76:6: error: conflicting types for 'FC_CAL_Port_Out_DDR__x'
 void FC_CAL_Port_Out_DDR__x (MX_UINT8* Port, MX_UINT8* Tris, MX_UINT8 OutMask, MX_UINT8 OutValue);
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_IO.c:1151:14: note: previous definition of 'FC_CAL_Port_Out_DDR__x' was here
  static void FC_CAL_Port_Out_DDR__x (GPIO_TypeDef *PORT, MX_UINT16 OutMask, MX_UINT16 OutValue)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_IO.h:77:10: error: conflicting types for 'FC_CAL_Port_In__x'
 MX_UINT8 FC_CAL_Port_In__x (MX_UINT8* Port, MX_UINT8 InMask, MX_UINT8 Shift);
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_IO.c:1166:18: note: previous definition of 'FC_CAL_Port_In__x' was here
  static MX_UINT8 FC_CAL_Port_In__x (GPIO_TypeDef *PORT, MX_UINT16 InMask, MX_UINT16 Shift)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_IO.h:78:10: error: conflicting types for 'FC_CAL_Port_In_DDR__x'
 MX_UINT8 FC_CAL_Port_In_DDR__x (MX_UINT8* Port, MX_UINT8* Tris, MX_UINT8 InMask, MX_UINT8 Shift);
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_IO.c:1172:19: note: previous definition of 'FC_CAL_Port_In_DDR__x' was here
  static MX_UINT16 FC_CAL_Port_In_DDR__x (GPIO_TypeDef *PORT, MX_UINT16 InMask, MX_UINT16 Shift)
In file included from C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\internals.c:591:0,
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_Delay.c:41:6: error: conflicting types for 'delay_s'
 void delay_s(unsigned char count);
In file included from C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\internals.c:542:0,
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_Delay.c:123:20: note: previous definition of 'delay_s' was here
 static inline void delay_s(uint32_t __s)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_Delay.c:42:6: error: conflicting types for 'delay_ms'
 void delay_ms(unsigned char count);
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_Delay.c:116:20: note: previous definition of 'delay_ms' was here
 static inline void delay_ms(uint32_t __ms)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_Delay.c:43:6: error: conflicting types for 'delay_10us'
 void delay_10us(unsigned int count);
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_Delay.c:110:20: note: previous definition of 'delay_10us' was here
 static inline void delay_10us(uint32_t __us10)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_Delay.c:44:6: error: conflicting types for 'delay_us'
 void delay_us(unsigned int count);
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_Delay.c:58:13: note: previous definition of 'delay_us' was here
 static void delay_us(uint32_t __us)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_Delay.c: In function 'delay_10us':
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_Delay.c:68:20: error: 'MCK' undeclared (first use in this function)
 #define US10COUNT (MCK / 800000)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_Delay.c:97:24: note: in expansion of macro 'US10COUNT'
  unsigned int i, max = US10COUNT * count;
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_Delay.c:68:20: note: each undeclared identifier is reported only once for each function it appears in
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_Delay.c: In function 'delay_us':
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_Delay.c:67:18: error: 'MCK' undeclared (first use in this function)
 #define USCOUNT (MCK / 7500000)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_Delay.c:104:24: note: in expansion of macro 'USCOUNT'
  unsigned int i, max = USCOUNT * count;
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_Delay.c: At top level:
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_Delay.c:109:6: error: redefinition of 'Wdt_Delay_S'
 void Wdt_Delay_S(char delay)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_Delay.c:145:6: note: previous definition of 'Wdt_Delay_S' was here
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_Delay.c:122:6: error: redefinition of 'Wdt_Delay_Ms'
 void Wdt_Delay_Ms(char delay)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_Delay.c:158:6: note: previous definition of 'Wdt_Delay_Ms' was here
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_Delay.c:133:6: error: redefinition of 'FCI_DELAYINT_US'
 void FCI_DELAYINT_US(MX_UINT16 Delay)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_Delay.c:168:6: note: previous definition of 'FCI_DELAYINT_US' was here
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_Delay.c:144:6: error: redefinition of 'FCI_DELAYINT_MS'
 void FCI_DELAYINT_MS(MX_UINT16 Delay)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_Delay.c:173:6: note: previous definition of 'FCI_DELAYINT_MS' was here
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_Delay.c:155:6: error: redefinition of 'FCI_DELAYINTWDT_MS'
 void FCI_DELAYINTWDT_MS(MX_UINT16 Delay)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_Delay.c:178:6: note: previous definition of 'FCI_DELAYINTWDT_MS' was here
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_Delay.c:166:6: error: redefinition of 'FCI_DELAYINT_S'
 void FCI_DELAYINT_S(MX_UINT16 Delay)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_Delay.c:183:6: note: previous definition of 'FCI_DELAYINT_S' was here
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_Delay.c:177:6: error: redefinition of 'FCI_DELAYINTWDT_S'
 void FCI_DELAYINTWDT_S(MX_UINT16 Delay)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_Delay.c:188:6: note: previous definition of 'FCI_DELAYINTWDT_S' was here
In file included from C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\internals.c:592:0,
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_String.c:124:17: error: redefinition of 'FCI_GETCHAR'
 static MX_UINT8 FCI_GETCHAR(MX_STRING sStr1, MX_UINT16 iStr1_len, MX_UINT16 iPos)
In file included from C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\internals.c:543:0,
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_String.c:124:17: note: previous definition of 'FCI_GETCHAR' was here
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_String.c:132:18: error: redefinition of 'FCI_GETLENGTH'
 static MX_UINT16 FCI_GETLENGTH(MX_STRING sStr1, MX_UINT16 iStr1_len)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_String.c:132:18: note: previous definition of 'FCI_GETLENGTH' was here
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_String.c:140:18: error: redefinition of 'FCI_MIDSTRING'
 static MX_STRING FCI_MIDSTRING(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_UINT16 iStart, MX_UINT16 iCount, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_String.c:140:18: note: previous definition of 'FCI_MIDSTRING' was here
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_String.c:170:18: error: redefinition of 'FCI_LEFTSTRING'
 static MX_STRING FCI_LEFTSTRING(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_UINT16 iCount, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_String.c:170:18: note: previous definition of 'FCI_LEFTSTRING' was here
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_String.c:193:18: error: redefinition of 'FCI_RIGHTSTRING'
 static MX_STRING FCI_RIGHTSTRING(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_UINT16 iCount, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_String.c:193:18: note: previous definition of 'FCI_RIGHTSTRING' was here
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_String.c:222:10: error: redefinition of 'FCI_TOSTRS16'
 MX_UINT8 FCI_TOSTRS16(MX_SINT16 iSrc1, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_String.c:222:10: note: previous definition of 'FCI_TOSTRS16' was here
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_String.c:265:10: error: redefinition of 'FCI_TOSTRS32'
 MX_UINT8 FCI_TOSTRS32(MX_SINT32 iSrc1, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_String.c:265:10: note: previous definition of 'FCI_TOSTRS32' was here
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_String.c:308:10: error: redefinition of 'FCI_TOSTRU16'
 MX_UINT8 FCI_TOSTRU16(MX_UINT16 iSrc1, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_String.c:308:10: note: previous definition of 'FCI_TOSTRU16' was here
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_String.c:342:10: error: redefinition of 'FCI_TOSTRU32'
 MX_UINT8 FCI_TOSTRU32(MX_UINT32 iSrc1, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_String.c:342:10: note: previous definition of 'FCI_TOSTRU32' was here
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_String.c:377:18: error: redefinition of 'FCI_TOSTRING'
 static MX_STRING FCI_TOSTRING(MX_SLONG iSrc1, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_String.c:377:18: note: previous definition of 'FCI_TOSTRING' was here
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_String.c:435:13: error: redefinition of 'FCI_TOLOWER'
 static void FCI_TOLOWER(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_String.c:435:13: note: previous definition of 'FCI_TOLOWER' was here
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_String.c:461:13: error: redefinition of 'FCI_TOUPPER'
 static void FCI_TOUPPER(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_String.c:461:13: note: previous definition of 'FCI_TOUPPER' was here
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_String.c:487:17: error: redefinition of 'FCI_COMPARE'
 static MX_UINT8 FCI_COMPARE(MX_STRING sSrc1, MX_UINT16 iSrc1_len, MX_STRING sSrc2, MX_UINT16 iSrc2_len, MX_UINT8 iNoCase)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_String.c:487:17: note: previous definition of 'FCI_COMPARE' was here
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_String.c:542:18: error: redefinition of 'FCI_FLOAT_TO_STRING'
 static MX_STRING FCI_FLOAT_TO_STRING(MX_FLOAT Number, MX_UINT8 Precision, MX_STRING String, MX_UINT16 MSZ_String)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_String.c:542:18: note: previous definition of 'FCI_FLOAT_TO_STRING' was here
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_String.c:609:18: error: redefinition of 'FCI_NUMBER_TO_HEX'
 static MX_STRING FCI_NUMBER_TO_HEX(MX_ULONG Number, MX_STRING String, MX_UINT16 MSZ_String)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_String.c:609:18: note: previous definition of 'FCI_NUMBER_TO_HEX' was here
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_String.c:676:18: error: redefinition of 'FCI_STRING_TO_INT'
 static MX_SINT32 FCI_STRING_TO_INT(MX_STRING String, MX_UINT16 MSZ_String)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_String.c:676:18: note: previous definition of 'FCI_STRING_TO_INT' was here
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_String.c:712:17: error: redefinition of 'FCI_STRING_TO_FLOAT'
 static MX_FLOAT FCI_STRING_TO_FLOAT(MX_STRING String, MX_UINT16 MSZ_String)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_String.c:712:17: note: previous definition of 'FCI_STRING_TO_FLOAT' was here
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_String.c:782:18: error: redefinition of 'FCI_STRREV'
 static MX_UINT16 FCI_STRREV(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_String.c:782:18: note: previous definition of 'FCI_STRREV' was here
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_String.c:806:18: error: redefinition of 'FCI_STRMOV'
 static MX_UINT16 FCI_STRMOV(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_String.c:806:18: note: previous definition of 'FCI_STRMOV' was here
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_String.c:826:13: error: redefinition of 'FCI_SHEAD'
 static void FCI_SHEAD(MX_STRING sSrc1, MX_UINT16 iSrc1_len, MX_STRING sSrc2, MX_UINT16 iSrc2_len, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_String.c:826:13: note: previous definition of 'FCI_SHEAD' was here
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_String.c:887:13: error: redefinition of 'FCI_SCOPY'
 static void FCI_SCOPY(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_String.c:887:13: note: previous definition of 'FCI_SCOPY' was here
In file included from C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\internals.c:593:0,
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_Float.c:63:24: error: expected identifier or '(' before 'long'
 #define flt_round(f) ((long)(((f)>=0.0)?(f)+0.5:(f)-0.5))
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_Float.c:47:25: note: in definition of macro 'flt_div'
 #define flt_div(a, b) ((a) / (b))
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_Float.c:71:32: note: in expansion of macro 'flt_round'
 #define fround(a, b)  (flt_div(flt_round(flt_mul(a,pow(10,b))),pow(10,b)))
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_Float.c:67:8: note: in expansion of macro 'fround'
 double fround(double val, int dp);
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_Float.c:63:29: error: expected ')' before '(' token
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_Float.c:47:28: error: expected ')' before '/' token
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_Float.c:71:24: note: in expansion of macro 'flt_div'
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_Float.c:82:11: error: redefinition of 'MX_Map'
 MX_SINT32 MX_Map(MX_SINT32 x, MX_SINT32 in_min, MX_SINT32 in_max, MX_SINT32 out_min, MX_SINT32 out_max)
In file included from C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\internals.c:544:0,
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_Float.c:78:11: note: previous definition of 'MX_Map' was here
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ARM\ARM_CAL_Float.c:87:10: error: redefinition of 'MX_Map_Float'
 MX_FLOAT MX_Map_Float(MX_FLOAT x, MX_FLOAT in_min, MX_FLOAT in_max, MX_FLOAT out_min, MX_FLOAT out_max)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\STARM_CAL_Float.c:83:10: note: previous definition of 'MX_Map_Float' was here
Error(s) in build
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\ARM\batch\stm32comp.bat reported error code 0x1
Autoclose turned off
FINISHED
Sadık Süme
celebriums
Re: Compiler error
Version 1.05 was working yesterday and yesterday I upgraded to version 1.06
After updating today morning, it started giving errors.
(245.7 KiB) Downloaded 196 times
STM32F446RE-V1.05_UART.fcfx
(275.67 KiB) Downloaded 204 times
Sadık Süme
Has thanked: 755 times
Been thanked: 817 times
Flowcode v10 Re: Compiler error
Hi Sadık.
Many thanks for reporting this.
I will show you how to get your project to compile again.
What you will need to do is rollback the internals update.
As there might be more than one person , including beginners, so I will use images to show how to rollback.
The steps are in yellow on the images.
First select Help > Library Updates...
Then Step 1. Change Files in-use to Full database
Step 2. Click on Show up-to-date files
Step 3. Only click on Internals.c
Step 4. select the drop down arrow and change the revision from 4 to 3
Step 5. Click on Download
Now the Updates window can be closed and then reload your project.
You can use File > Reload or the Reload Icon next to the save icon at the very top on the left.
Reload Icon.png (3.08 KiB) Viewed 4810 times
I hope this helps to get your project working again.
celebriums
Re: Compiler error
Yes, dear Martin, I'll take a look at my old computer.
I re-downloaded version 3 of Internals.c and it was fixed.
I was about to write to you about this and I just saw your message now.
Thank you very much for the information.
Sadık
Sadık Süme
Re: Compiler error (SOLVED) internal.c ver 3
The fixed file is now on the component database.
You can now update to the correct version by changing Files in-use to Full database.
This time don't have Show up-to-date files enabled.
After updating the component, you will need to reload your project.
