Pico Compiler toolchain
Amrat
Has thanked: 1 time
Post by Amrat »
Floecode V10.1.1.39 try compile PICO target got message " No Compiler for PICO" ??
Please advise where can I download ?
Has thanked: 435 times
Been thanked: 651 times
Re: Pico Compiler toolchain
Info is in the Flowcode WiKi
https://www.flowcode.co.uk/wiki/index.p ... _Toolchain
Amrat
Has thanked: 1 time
Post by Amrat »
But it look quite complicated !! Any easier way ? Like a single installer file ?
Amrat
Thanks again
Not that I am aware of. The instructions are quite straight forward and I had no trouble in installing.
Amrat
Has thanked: 1 time
Post by Amrat »
Dear Chipfry,
Yhanks for your advice n will do.
Thanks Again
Amrat
Amrat
Has thanked: 1 time
Post by Amrat »
Dear Chipfry,
Re: Pico
I try as per Wiki step, befor installing Raspberry Pi Toolchain. Then install Raspberry Pi last, restart com. Stll cant run got message
"PICO compiler toolchain is not installed !!!"
Pleas advice again
Amrat
Has thanked: 713 times
Been thanked: 775 times
Have you added the path of the PICO toolchain to File > Global Settings... > Locations tab > PICO: section ?
Amrat
Has thanked: 1 time
Post by Amrat »
Hi Medelect35,
Thanks. I did not add path thats why may be not working.
Thanks for advice
Amrat
That's great!.
Thanks for letting us know.
Amrat
Has thanked: 1 time
Post by Amrat »
Hekko Friends,
I am total helpless in running PICO Pi !! I have installed all files as per wiki and had set path but still cant compile.
Can anyone explain in detail by step ? Will really be grateful.
Amrat
