UART Macro wont compile after update.
jay_dee
Has thanked: 102 times
Been thanked: 74 times
Post by jay_dee »
If I enable a certain user macro, it wont compile. This macro uses UART and has run without fault for many years.
Fault exists in both software and hardware mode.
C:\Users\jdwed\Desktop\FlowCode>"C:\Program Files (x86)\Flowcode\Common\Compilers\picv2\bin\xc8-cc.exe" -mcpu=18F4680 "VT100_Test.c" -w=359,1273,1388 -fno-short-float -fno-short-double -std=c90 -Os
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_String.c:871:: error: (712) can't generate code for this expression
(908) exit status = 1
Error returned from [xc8.exe]
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\PIC\batch\pic_xc8_comp.bat reported error code 0x1
I have thinned the entire FC and Macro down to just a few lines and single call. Still wont compile. example below.
VT100_Test.fcfx
(11.61 KiB) Downloaded 329 times
I've run latest updates and restarted FC. thanks, J.
FC 10.1.2.40
Sasi
Has thanked: 43 times
Been thanked: 15 times
Re: UART Macro wont compile after update.
Post by Sasi »
Hi jay_dee,
Change the compiler to XC8 v2.50. This will make the compilation work and hopefully the UART as well.
Regards, Sasi
jay_dee
Post by jay_dee »
Hi, Thanks.
Latest version on Microchip website if Ver 3.00. Is the recomendation to roll back to v2.50? or is 3.00 good?
If I installed the latest 3.00 XC8 compiler directly would I need to re-direct the FC complier settings?
Global Settings / Locations / PIC - change path to new compiler install location.
It was: C:\Program Files (x86)\Flowcode\Common\Compilers\picv2\
change to: C:\Program Files\Microchip\xc8\v3.00\pic\
having done this I still get the same error.
thanks, J.
Sasi
Post by Sasi »
Flowcode is currently not compatible with v3.00.
It only compiles with v2.50, which you can find in the compiler archives on the Microchip website. Your procedure for replacing the compiler is correct.
I have a similar problem with a PIC18F46K80 MCU. viewtopic.php?t=3097
If the UART works, please check if the input ports work on yours. Because I have problems with them.
Sasi
jay_dee
Post by jay_dee »
Sasi, Thanks. I installed and linked to V2.50 and the program now compiles without issue.
Unfortunatly I dont have any AV inputs to check for you. I'm doing everything through I2C and a Single UART Tx pin.
I run the comms to the PC using Hardware UART @57600.
I would be interested in any thoughts from the FC team, as I'm keen to keep my install as standard as possible to avoid issues with new FC upgrades.
J.
Has thanked: 794 times
Been thanked: 853 times
I have noticed that it's the 18F series that has the problem, and not the 16F series.
As an alternative, can you try the following to fix using compiler that is on the Flowcode's download page.
You will either need to copy or edit pic_xc8_comp.bat found within
%ProgramData%\MatrixTSL\FlowcodeV10\FCD\PIC\batch\
Within pic_xc8_comp.bat
Change the
Os
at the end of
"%MX_COMPILER%bin\xc8-cc.exe" -mcpu=%MX_CHIP% "%MX_PROJECT%.c" -w=359,1273,1388 -fno-short-float -fno-short-double -std=c90
 O1
So you should have
"%MX_COMPILER%bin\xc8-cc.exe" -mcpu=%MX_CHIP% "%MX_PROJECT%.c" -w=359,1273,1388 -fno-short-float -fno-short-double -std=c90 -O1
Save then recompile.
Or
If you want to keep the original pic_xc8_comp.bat
Copy the original pic_xc8_comp.bat, rename it to something like pic_xc8_comp_18F_Only.bat
Make the required change, then save it.
Within Build > Compiler Options...
Click on the Save Icon
Enter the name you would like for the modified pic_xc8_comp_18F_Only.bat
Scroll down and select the new compiler name, then make sure the Default compiler for the platform C for PIC is ticked.
Select OK
Niote, you will probably find that the size of generated code is a bit larger since the new settings change Optimisation from
-Os (Optimize for Size): Focuses on reducing code size as much as possible.
to
-O1 (Basic Optimization): Balances speed and size, providing moderate optimizations without overly aggressive changes.
@Sasi I wonder if the above will sort your issues out?
Sasi
Post by Sasi »
Hi Martin,
I tried what you suggested. This modification seems to help.
The digital input portbit now works with the XC8 v2.50 compiler. :D
viewtopic.php?t=3102
The "SendString" UART Component Command still only works with the v2.50 Compiler. :)
I'm moving to the v2.50 compiler and hope everything will be fine.
Thank you very much.
Sasi
You're welcome, and lets hope so.
The compiler seems to be a pit of a pain when it comes to 18F series.
I'm glad the inputs now work for you.
Thanks for letting me know.
Sasi
Post by Sasi »
Unfortunately, this hasn't given me a solution.
Maybe I had multiple projects open at the same time while testing, and I only changed the compiler in one of them. :?
Can you try the attached with the toolchain that is on Flowcode's download page.
Browse to this location using file explorer, it's hidden by default so just paste the link into your address bar.
%ProgramData%\MatrixTSL\FlowcodeV10\CAL\PIC
Place the attached C file.
If you run any library updates, then the PIC_CAL_String.c you added will be overwritten, so it will stop working again (unless the PIC_CAL_String.c update has been pushed).
PIC_CAL_String.c
(45.18 KiB) Downloaded 279 times
