MQTT not connected with Windows 11
Nico595
Has thanked: 20 times
Been thanked: 5 times
Flowcode v10 MQTT not connected with Windows 11
Post by Nico595 »
I check my Pc App MQTT project with some Windows version. All good with Windows 7, Windows 10 but with Windows 11 I have the message "not connected". The return of MQTTClient1::Connect() Component is 0.
I tried with MQTT Explorer tool, I can connect and subscribe topic in mqtt and ws from the same PC.
I opened 1883 and 8883 tcp port in the Windows Firewall, I also open all communications from the FC runtime exe file.
"not connected" message is displayed when Is_Connected = 0 in the first condition of MQTT connection step.
I have only this problem with Windows 11, others Windows work fine with the same Pc App project.
Please can you check this ?
It's may be a new problem from the Runtime file.
EDIT: I tried with the local IP of the Host, but same problem.
Thank you.
PS: I know that Windows 11 is again a very bad OS from Microsoft but I must check this for my customers.
Nico595
Re: MQTT not connected with Windows 11
Post by Nico595 »
On the Windows 11 computer I have "Ethernet 2"
I tried with "AutoDetect" in the Network Interface Parameter of NetworkComms Component but without result.
Has thanked: 443 times
Been thanked: 664 times
I've never got AutoiDetect to actually detect in W11, so I try each option until the field gets populated.
Nico595
Post by Nico595 »
Hi Chipfryer,
Thank you for your answer.
In fact, I have not FC10 Installed on the Windows 11 Computer, only the Pc App project with the runtime files.
May be I can create a box with the Channel option to change it if "0" don't work.
I will try this :)
EDIT: I added box to enter the number of Network comms, when I wrote 1 and clicked on the connect button, Pc App was connected :)
Thank you so much for your Help.
