I'm compiling another flowchart and it showed four messages that hadn't been presented.
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_IO.c: 216: non-reentrant function "_FC_CAL_Port_In_DDR__x" appears in multiple call graphs and has been duplicated by the compiler
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_Delay.c: 105: non-reentrant function "_delay_ms" appears in multiple call graphs and has been duplicated by the compiler
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_Delay.c: 128: non-reentrant function "_Wdt_Delay_S" appears in multiple call graphs and has been duplicated by the compiler
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_Delay.c: 141: non-reentrant function "_Wdt_Delay_Ms" appears in multiple call graphs and has been duplicated by the compiler
Compilation successful!
Using <PICKIT3> user settings for linker
C:\Program Files (x86)\Flowcode v10\tools\DoNothing\DoNothing.exe
FINISHED
Enrique
error or bug
ELECTRONICA67
- Has thanked: 31 times
- Been thanked: 9 times
- Has thanked: 163 times
- Been thanked: 960 times
Re: error or bug
This happens if the function cannot be interrupted and then restarted.
Common issues are use of global variables, hardware registers or (less likely here) static local variables.
Calling routines that require some saved state from ISRs etc will cause issues and is not a good idea.
Can you post a snippet of code that demonstrate?
ELECTRONICA67
Re: error or bug
Hello Martin,
In fact, I just compiled a finished flowchart that didn't show that message. I compiled it and it also showed that message, which wasn't present in compilations prior to 2 or 3 days ago.
ELECTRONICA67
Re: error or bug
This is a published example that outputs 1 message.
- IOC_Pulse_Counter.fcfx
- (21.33 KiB) Downloaded 168 times
ELECTRONICA67
Re: error or bug
Yes... it was updated yesterday, I had also reported something similar but with the string function, which was corrected with that update, but now apparently these new messages have appeared, which were not present a few days ago, they appeared after yesterday's update.
ELECTRONICA67
Re: error or bug
I just updated with patch 10.1.2.40 but 3 messages continue to appear. A few days ago none of these messages appeared in that same flowchart.
- 2.jpeg (167.34 KiB) Viewed 6823 times
ELECTRONICA67
Re: error or bug
I'm to update Flowcode... the same thing has happened to me the last 2 or 3 times I've updated.
ELECTRONICA67
Re: error or bug
I don't know if these messages affect the correct functioning of the program in any way.
ELECTRONICA67
Re: error or bug
On another computer where I haven't downloaded the last 2 patches, I don't get those messages.
