After upgrading the libraries, compile to target doesn't work again. Although I tried reloading, reloading the ESP libraries...
Can you check for me where the problem is? I'm attaching the LOG file.
Best regards
Compiler error
Frco007
- Has thanked: 3 times
- Been thanked: 1 time
- Has thanked: 175 times
- Been thanked: 997 times
Re: Compiler error
'FCD_066a1_TCP_IP_W5500__DHCP_Run':
C:/FC_ESP/mtxesp32s_sdkconfig/main/esp-project.c
10: error: 'FCR_RETVAL' is used uninitialized [-Werror=uninitialized]
Looks like a return value isn't set here - which is treated as an error
- Has thanked: 756 times
- Been thanked: 819 times
Re: Compiler error
Many thanks for reporting this issue.
I have fixed the component, so hopefully you will be able to compile ok after following the steps below.
Place the attached component.
Can you please let me know how you get on.
%ProgramData%\MatrixTSL\FlowcodeV10\ComponentsIf Flowcode is already open, then you will need to reload your project for the new component to work
- TCP_IP_W5500.fcpx
- (20.18 KiB) Downloaded 267 times
