Can't access the Flowcode Web Developer Deployment Window
canary_wharfe
Has thanked: 15 times
Been thanked: 16 times
Post by canary_wharfe »
Can't access the Flowcode Web Developer Deployment Window:
I used to go to File > Export > Deploy as Flowcode App.
Configuring the App:
The deployment window will appear, allowing you to choose which components, panels, and views to include in the final application. You can also manage resources like bitmaps or audio files.
BUT
Now the deployment option window doesn't appear it goes straight to compile and a windows message informing me the project was successfully compiled.
Can someone help me get the deployment window back showing all the options? I'm goin crazy here! I'm desperate. :o
< The Flowcode 11 Pro Silicon Chipper >
Has thanked: 443 times
Been thanked: 664 times
Re: Can't access the Flowcode Web Developer Deployment Window
Are you mixing up deploying Web Developer with App Developer?
It has been a while since I used Web Developer (and I'm just going to go refresh my memory), but I don't recall offhand seeing those options. They are available in App Developer though.
canary_wharfe
No the option was available and now it's gone (web app developer). I set one of the options for the HTML web page to run immediately on start up when the html file was clicked. I want to turn the run on startup to OFF and I can't get back to the settings page to do that.
Okay
I've got a machine that I've not updated in a while so I will check on that to see if there.
canary_wharfe
Ummm ... I think perhaps you're right and I'm just imagining it. Just set up a PC app developer test project and the deployment options page comes up as you suggested. I must be losing it ... the trouble is I've played around so much with both web developer and PC developer in the last week trying to catch up and get up to speed with Flowcode features I haven't used before ... and this damned heat and humidity ... i literally must have dreamed the entire thing re. web developer.
