Hi to All
I have the ESP32 C3
I can compile and download to target and it's running
(no press of reset and boot)
I use the GPIO18 and GPIO19 like the schema for UART/USB
But as soon as I switch on the Uart in FC10 and flash I can not connect anymore the ESP to the computer,
there is no com port anymore also not in the terminalprogram.
For the next flash I need to press reset and boot first
https://docs.espressif.com/projects/esp ... ction.html
ESP32 C3 UART USB problem
- Has thanked: 246 times
- Been thanked: 257 times
- ESP32_C6_post.fcfx
- (9.18 KiB) Downloaded 482 times
- (view online)
- Has thanked: 637 times
- Been thanked: 847 times
Re: ESP32 C3 UART USB problem
It looks like on that device there may not be a UART to USB bridge IC and so they expect you to use the USB peripheral as the comms. We don't currently support the USB on the ESP32 devices but I could add it to the list to investigate if that would help.
UART to USB bridge IC are often relatively large so that they are missing in the very small board.
Yes, that would be very good if it follows in a few weeks.
I am always ready to test it.
I think we will also look at the App Developper to have an easy to use and very fast USB connection for the ESP32 (without UART to USB bridge).
Hi Stefan,
I've made a good start with this now and aim to finish it off next week in between doing other things.
Atm it's looking very good and easy to implement and will become part of the standard USB Serial component.
- Has thanked: 177 times
- Been thanked: 1021 times
Quick question on this - does the chip output the usual stream of debug info to USB (if so then there is a link to USB as stands)
Hi Marrtin
No stream of debug info to USB possible...
I can't use USB with Atom S3 with display either.
The Pin's go direct from ESP32 to USB pin
A USB component would be useful for transferring data.
I don't have any options with Bluetooth either.
Did you get the S3 to work?
Just tested with a C3 and using the JTAG / USB link and printf("string"); works well with this variant too! So you could output to USB and 'catch' the data in App Developer here too?
Note that you can use printf with optional arguments for example printf("Value = %d\r\n", FCL_VAL); to print an integer value.
Hi Martin
I think only the S3 has this option, a built-in UART to USB bridge.
This is not possible with the C3. I should also be able to reach 921600 baud and send and receive integer arrays to the AppDeveloper.
At the moment, I am still using the ESP32 WROOM, but I would also like to use hardware with the C3 and S3.
These are small and require less power.
