DSP_ILace Compilation error
Been thanked: 3 times
Post by 17712885438 »
DSP_ILace Compilation error.Please help me, thank you.
DSP_ILace.fcfx
(20.17 KiB) Downloaded 477 times
(20.17 KiB) Downloaded 3 times
Target folder: E:\flowcode exp
Source name: E:\flowcode exp\Flowcode1.fcfx
Title:
Description:
Device: ARD.ATMEGA.ATMEGA328P
Generated by: Flowcode v10.1.2.40
Date: Wednesday, October 29, 2025 09:27:24
Users: 1
Registered to: niedian (33762713)
Licence key: AF2WAB
https://www.flowcode.co.uk
Launching the compiler...
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\AVR\batchfiles\avra.bat "C:\Program Files (x86)\Flowcode\Common\Compilers\avr\" atmega328p "E:\flowcode exp\Flowcode1.elf" "E:\flowcode exp\Flowcode1.c" "E:\flowcode exp\Flowcode1.lst"
E:\flowcode exp>REM CRC: EA277D0C7EF9B4E537B79187D0BE7A25FA6080B4B01BE48BAF713429E4B690411241251B4A05C2B5828F4452C9F7348705C640EF477B79E0C7881D2E5EEC9BD69A0D46BD3B6AACB92DE4D84759EBB5079CA9DA2D2BBCDAE2A4D1C56CD1580BF5A24465F11D9C3B2DBA3F4E37F13004EE3637760F1F0B7DA0CC623CD30E3C7D6BAB4C3FE6151D92B8EC0ADD55E96639DAC02472BDE3806EF43AE3A028BD32A5DAE68BB191DA97CB6883A66D3C41849952BB2DD264AF32733E2C3050DA273BE4EE1FA30153290F2FAFBD2259D77AD477809E9C4D76400384BA5D2E1919BC6D834D57C406BC4A49D3F1
E:\flowcode exp>REM REVISION: 1.0
E:\flowcode exp>REM GUID: EA0828B2-5C70-41A5-8C54-F359DD5CC88B
E:\flowcode exp>REM DATE: 08\08\2022
E:\flowcode exp>REM DIR: FCD\AVR\batchfiles\avra.bat
E:\flowcode exp>"C:\Program Files (x86)\Flowcode\Common\Compilers\avr\bin\avr-gcc.exe" -mmcu=atmega328p -Os -ffunction-sections -fdata-sections -funsigned-char -o "E:\flowcode exp\Flowcode1.elf" "E:\flowcode exp\Flowcode1.c" -lm -Wl,-gc-sections
E:\flowcode exp\Flowcode1.c: In function 'FCD_0bb62_DSP_ILace1__Interlace':
E:\flowcode exp\Flowcode1.c:1223: error: 'FCV_0bb62_DSP_ILace1__INDEXIN1' undeclared (first use in this function)
E:\flowcode exp\Flowcode1.c:1223: error: (Each undeclared identifier is reported only once
E:\flowcode exp\Flowcode1.c:1223: error: for each function it appears in.)
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\AVR\batchfiles\avra.bat reported error code 0x1
Autoclose turned off
FINISHED
