ESP32 "Flash EEPROM"
dvcam99
Has thanked: 9 times
Been thanked: 14 times
Flowcode v9 ESP32 "Flash EEPROM"
Post by dvcam99 »
Hello FC community,
I`m looking for a way in order to store and receive byte values into ESP32 flash.
Unfortunately the Flash EE Prom Component is not working. I`ll get a compiler error.
Any suggestions is apreachiated and welcome.
BR
Dirk
Happy FC9, FC-8 and FC-6 professional user ;)
Has thanked: 246 times
Been thanked: 258 times
Re: ESP32 "Flash EEPROM"
Hi Dirk
I don't know if this will help you.
I have several ESP32s, each with a fixed calibrated sensor.
For each ESP32, there are values from the calibration machine that are stored in the Flowcode program.
I read the MAC address from the ESP32 and then assign the appropriate values.
read mac adress for matching data:
https://flowcode.co.uk/forums/viewtopic.php?t=3407
Has thanked: 177 times
Been thanked: 1026 times
Post by mnfisher »
The esp32 doesn't really have any EEPROM - you can use flash memory as persistent store, or the RTC has some memory that is non-volatile too.. There is a post about SPIFFS and also using RTC memory - though will take a bit of searching..
viewtopic.php?t=2642&hilit=spiffs
viewtopic.php?t=679&hilit=rtc+memory
Note that both these posts are quite old - and with the rapidly changing esp32 environment might take a little work to get going...
dvcam99
Post by dvcam99 »
Many thanks Martin,
I will check your suggestion.
BR
Dirk
Has thanked: 478 times
Been thanked: 713 times
Using an ESP "lolin-lite" I have used the EEPROM 2D component to good effect. As Martin states above it isn't really EEPROM but not so much you'd notice :) It saves data and can be read back upon reboot etc. It would probably work for other variants and no harm in trying.
dvcam99
Post by dvcam99 »
Hello guys,
I can confirm that the Code Abstraction Layer EE-Prom will work an do the job.
Thanks for pointing me in the right direction.
BR
Dirk
Screenshot 2025-11-07 150114.png (4.62 KiB) Viewed 2001 times
