Interrupts
alanwms
Has thanked: 26 times
Been thanked: 8 times
Interrupts
Post by alanwms »
Using PIC18f27q10. FC11
I have two interrupts. One is a hardware input interrupt. The other is a timer0 interrupt. I believe that priorities are settable but requires a few c code register adjustments such as (maybe):
IPR0bits.INT0IP = 1; // High priority
IPR0bits.TMR0IP = 0; // Low priority
I don't seem to be able to locate these registers in the data sheet, but this seems to compile ok.
If you have any details on this, I would appreciate feedback but.... - If I do not assign priorities, what default priority takes place?
Has thanked: 724 times
Been thanked: 783 times
Re: Interrupts
For Timer 0 and IOC interrupts High Priority, try:
INTCONbits.IPEN = 1;    // Enable priority mode
IPR0bits.TMR0IP = 1;    // Timer0 = HIGH
IPR0bits.IOCIP = 1;     // IOC = HIGH
INTCONbits.GIEH = 1;    // Enable high priority interrupts
For Timer 0 High Priorit yand IOC interrupt low, try:
IPR0bits.IOCIP = 0;     // IOC = LOW
INTCONbits.GIEL = 1;    // Enable low priority interrupts
Or
INT0:
Always high priority
INT1:
IPR0bits.INT1IP = 1;  // High priority
IPR0bits.INT1IP = 0;  // Low priority
INT2:
IPR0bits.INT2IP = 1;  // High priority
IPR0bits.INT2IP = 0;  // Low priority
Without setting any priority bits, you get:
INT0 = HIGH priority (automatic)
INT1 = LOW priority (default)
INT2 = LOW priority (default)
Timer0 = LOW priority (default)
IOC = LOW priority (default)
All other interrupts = LOW priority (default)
So if you want any interrupt besides INT0 to be high priority, you must explicitly set its priority bit to 1.
I hope this helps.
alanwms
Re: Interrupts
Post by alanwms »
Martin! Thank you... Happy New Year.
