Kitchen Timer project using 16x LEDs and 2x 74HC595
andeug
Has thanked: 40 times
Been thanked: 6 times
Flowcode v11 Kitchen Timer project using 16x LEDs and 2x 74HC595
Post by andeug »
I am working to learn FC11 and am stuck on a project that involves a Click Ring from Mikroe with 32x LEDs (of which I am using only 16x LEDs), connected to an Arduino Nano 328 at 115200 baud. The schematic involves the following block components:
Digital timer with 16x LEDs and 2x 74HC595.pdf
(3.89 MiB) Downloaded 356 times
I had to do the mapping of the segments via ChatGPT, and I received the following, which I tested, and it works:
7seg_combinations.xlsx
(16.15 KiB) Downloaded 334 times
Now I am stuck with the Main macro, on which I need to work with variables, the pushbutton(s) PB1 (and eventually PB3), and time counting.
The way I thought the project was straightforward. They are the following times are pre-configured in Macros:
1 minute
2 minutes
3 minutes
4 minutes
5 minutes
6 minutes
7 minutes
8 minutes
9 minutes
10 minutes
15 minutes
20 minutes
25 minutes (Pomodoro cycle)
30 minutes
45 minutes
60 minutes
How should the timer work? I will explain below:
When I press PB1 once, the timer starts for 1 minute, and after 2 seconds, it begins blinking, indicating it will count 1 minute.
For the 1-minute configuration, I have used "solid" via "T_01min_indicator", and "blinking" state via "T_01min_blink".
When I press PB1 once, the timer starts for 2 minutes, and after 2 seconds, it begins blinking, indicating it will count 2 minutes.
For the 2-minute configuration, I have used "solid" via "T_02min_indicator", and "blinking" state via "T_02min_blink".
For the 2-minute indication, it needs to start with "T_02min_indicator", "T_02min_blink" and then "T_01min_blink".
... and so on. The problem with this approach is that if I am making a mistake in one "minutes" loop, the whole program will not work as expected. Shall I use a different approach instead? Below is what I have created:
The kitchen timing in minutes is calculated by looping through the Macros associated with the counted time.
The challenges that I am experiencing are:
- The "Switch" option only has 10x possible states, while I have 16x.
- I do not know if I should use "Switch" or "Decision" while I am pressing the button and toggling through the minutes that I need to have counted.
- Shall I use only the "Buzzer" component, or "PWM", to generate sound on the buzzer with various intensities? (medium or high)
- Shall I use "Keyboard interrupt" for something, given the simplicity of the whole design?
Can someone please help me with this project?
Andreas
andeug
Re: Kitchen Timer project using 16x LEDs and 2x 74HC595
Post by andeug »
The schematic of the LED Ring Click:
Led Ring R Click schematic.pdf
(346.48 KiB) Downloaded 348 times
The schematic of the 2x2 key Click:
2x2 Key Click schematic.pdf
(288.66 KiB) Downloaded 349 times
The picture of the whole assembly (I prefer off-the-shelf components to save time, instead of soldering):
Has thanked: 177 times
Been thanked: 1027 times
Post by mnfisher »
I don't have access to any hardware (or indeed Flowcode) at the present. However, i would try and create a single macro Blink (count, pattern1, pattern2) rather than using individual macros for each time period.
Select the patterns using a lookup table (either the component or an array) with index as minutes.
Then it is a simple matter to step through the lookup table for each time
To clarify a bit. Button increases time...
.time = 0. // Device off
Increase .time on button press. (One press gives one minute).
.count = lut[1][0]
.pat1 = lut[1][1]
.pat2 = lut [1][2]
Blink(.count, .pat1, .pat2)
Where lut is defined as an array[16][3] for example if you have 16 possible time periods...
andeug
Post by andeug »
Hi Martin,
Thank you for your feedback. I have managed to build the project using the look-up table that you have suggested.
Now, the problem that I have is with the buzzer - it does not work, and it does not want to respond to the 4,000Hz frequency of the simulation. On the PC it works as a simulation (it acts as an active buzzer), but mine is passive, and it has the product code EPT-14A4005P, made by Sanco Electronics.
BUZZ Click schematic.pdf
(164.86 KiB) Downloaded 323 times
I want the volume to start lower and, after 5 seconds, increase, motivating the user to stop the timer. How do I do this?
Also, the shift registers are being "corrupted" after a few loops, indicating a sync/timing issue in the code. Would you happen to know where the problem is? Any suggestions on optimizing the flow code are welcome.
Andreas
Digital timer with 16x LEDs and 2x 74HC595.fcfx
(28.93 KiB) Downloaded 301 times
Has thanked: 478 times
Been thanked: 713 times
You have two buzzers connected to the same pin, a piezo buzzer (EPT-14A4005P) and a simple fixed frequency buzzer. Which one do you intend to use?
I assume the piezo, so delete the other one and all related chart icons.
For the piezo to work you will need to use PWM and set it to roughly 3800Hz. In properties you can set the target frequency and FC will attempt to create the closest match. Remember to set "Apply to defaults" to "yes". FC will then calculate how to create this frequency using a timer.
Now you can use the PWM component macros to enable / disable / set duty cycle (to control the volume) etc.
Post by mnfisher »
HI Andreas,
When you say the buzzer does not work - is that at all / or just has a constant volume?
It looks as though you have a buzzer component - and this would connect to the the GPI pin on the buzzer board - this only provides on or off (with no option to control volume). Using the PWM channel (which should be connected to a different pin) - you can alter the tone / volume by setting the PWM frequency and duty cycle - it might take a bit of fiddling to get a harmonious note? At present you don't seem to use this - but setting the appropriate values and then doing Enable should allow this? (and I think you then use one or other to control the buzzer)
I think the loop logic is slightly wrong - at some point the DisplayTime macro is called with -1 (or 255) (at least in simulation) - which will load the shift register with an unknown value.
Iain's beat me to it....
