AirMar P66 speed calculation problems
viktor_aust
Has thanked: 18 times
Been thanked: 5 times
Post by viktor_aust »
The duration between two pulses calculation question.
I have an AirMar P66 transducer.
Not a smart one, but the analogue one.
Has anybody read the paddle wheel speed from this transducer?
And maybe the depth sensor as well?
Thanks.
Has thanked: 163 times
Been thanked: 960 times
Re: Duration measurement between two pulses
Post by mnfisher »
Depending on the length of pulse - you might might able to use the capture and compare module of the MCU.
See viewtopic.php?t=3111&hilit=Pulse+measurement - though I've also posted code for AVR...
viktor_aust
Thanks mnfisher
I was thinking to stay away from c-code for a while.
I am not sure if I can.
Some suggest to set the Timer1 (Atmega328) to 1024 prescaler.
16 MHz / 1024 = 15625 Hz.
1/15625 = 0.000064 seconds
65536 * 0.000064 = 4.19 seconds.
Where 4.19 is the Timer1 overflow duration (is it?)
The boat speed = 1 / (4.19 * Period (in seconds)
If the found time (period) between two pulses = 4.7s
Speed = 1 / (4.19 * 4.7) = 0.05 knots.
Look like the above method constantly compares the reference time (4.19s)
to the found duration between two pulses.
I am not sure what is better:
1- use the c-code for Timer1 (Atmega328). I think timer1 has outputs PB1 and PB2. When B1 or B2 changes the state, the interrupt macro saves the time
value between pulses. This value is used to calculate the boat speed.
2- Use the flowcode two timer components. Set the timer1 to count 4.19s. During that time the interrupt triggers the timer2 component to measure the
After that I can use the formula: The boat speed = 1 / (4.19 * Period (in seconds)
Any suggestions?
Thanks.
Post by mnfisher »
If the time interval is ~4s - then record the start time on one interrupt, the end on the next (using a timer component to get the time on ms (or us)) and calculate the difference.
Should be able to avoid C.
I can do a small example if needed?
viktor_aust
Would be good. Thanks.
Post by mnfisher »
Hi Viktor,
A simple example - I've assumed that you want to measure the time the pulse is HIGH - but the same can be applied to a LOW signal. The very simple test signal generator - gives equal time HIGH and LOW (here 2s) - though this isn't necessarily the case (and the measurement 'ignores' the time LOW).
I had a bit of an issue with the timer component - see bugs :-( but using TMR0 seems to give reliable results (using TMR2 - 16016ms!). The 2s 'pulse' shows as 2016ms - there is some loop overhead for the pulse generator (for the loop and pin toggle)
pulse_328p.fcfx
(14.83 KiB) Downloaded 263 times
pulse_gen.fcfx
(7.65 KiB) Downloaded 264 times
viktor_aust
Many thanks mnfisher.
Will post results shortly.
Post by mnfisher »
Will be interesting to hear how it goes!
viktor_aust
What I have to do - I need to use the created by Timer1 time as the reference value and calculate the time duration between the two pulses from the paddle wheel from P-66. The more I think about it the clear I see the need to use c-code. I am busy right now with the different projects. Not sure when I will be able to finish this one. I hoped that someone did some work with the marine analogue transducer. All good. Thanks.
Post by mnfisher »
Just looking at the AirMar P66 transducer data - and looks like the speed reading is given by pulse frequency (~5.6Hz at 1knot for example). So rather than measuring the pulse length - measuring the number of pulses over a given period might be an easier option? So count rising edges over 10s (or more - I've no idea how quickly you need to read this - but 56 pulses/10s is easily readable?). Alternatively you should be able to calculate an instantaneous frequency from a single pulse and a little maths?
None of this should need C code.
Depth measurements seem to be a different kettle of fish?
Let us know when you can work on it - I'm sure someone will help out.....
