AppDeveloper How to use CSV read/write
Has thanked: 246 times
Been thanked: 258 times
Flowcode v11 AppDeveloper How to use CSV read/write
Writing a file works perfectly, if I use delay
reading doesn't go so well
I don't know exactly how to use CSV read/write.
Writing a CSV file works well with the next row command.
But when reading the CSV file, I don't know if I need the command.
Sometimes when creating and writing the file, I end up with an empty file.
If I already have an empty file, then it works fine when I start the program a second time.
I don't know where I need to wait.
Sometimes I still get a lot of 000000 if I open it with notepad.
One command gets stuck readAsNumber(1,0) but the others work.
Testprogram:
post_csv1.fcpcd
(44.24 KiB) Downloaded 175 times
Re: AppDeveloper How to use CSV read/write
I have written a file that generate 10 files and some with extra long filename.
A problem is with the simulation speed.
Can I set it always to full speed?
So I'll start testing “reading CSV into an array.”
The file I need to read has about 12,000 lines.
If this is on second place and the file is small, there is a problem
If this is on first place
it's perfect without a delay and short or long files are ok
With the lot of zeros it's just write number a problem, write int and write strg is ok.
I think it's because of write float (and not a problem).
Testprogram:
post_csv_write2.fcpcd
(15.61 KiB) Downloaded 133 times
I wrote a program to read a csv file generate from an FC11 App.
Sensor_1_FC11.csv is the original file
Senser_1_excel_4row.csv is open and save in excel as csv file.
the comma at the end is gone after save.
read seq ist working if I add some read but this does not match anymore after excel
read number is not working (anymore)
program
post_csv2_read.fcpcd
(29.91 KiB) Downloaded 152 times
csv file:
Sensor_1_FC11.csv
(538.78 KiB) Downloaded 150 times
Sensor_1_excel_4row.csv
(170.18 KiB) Downloaded 147 times
