Compile problem with FC11
B2CAP-V6
Been thanked: 7 times
Post by B2CAP-V6 »
I now have another problem: when I compile the flowchart, the compiler returns error messages that I didn't get before. I haven't changed anything except that I installed MPLAB XIDE v6.3, because I bought a Microchip development board (Curiosity Low Pin Count (LPC) Development Board kit) to be able to test the programs in a real-world environment (but it doesn't work in MPLAB either; the compilation also returns errors). Do you have any idea what the problem might be? It's probably related to XC8, but I can't see where.
Thermo_Baro.fcfx
(25.22 KiB) Downloaded 568 times
Has thanked: 291 times
Been thanked: 458 times
Re: Compile problem with FC11
What error messages are you seeing?
Please post your ".msg.txt" file as well as the ".fcfx" file as this will often allow us to debug the problem without needing to download and compile your project. It will also rule out any differences in the setup of your toolchain.
B2CAP-V6
Post by B2CAP-V6 »
Hi Steve,
You can find in attachment the files.
Thermo_Baro.msg.txt
(5.09 KiB) Downloaded 489 times
Thermo_Baro.fcfx
(25.22 KiB) Downloaded 474 times
Has thanked: 103 times
Been thanked: 302 times
You seem to be running an old version of XC8 (V1.45)
Looks like your PIC compiler path is "C:\Program Files (x86)\Flowcode\Compilers\pic\"
This would normally be "C:\Program Files (x86)\Flowcode\Common\Compilers\picv2\"
Please check toolchain location in Global Settings->Locations->PIC
B2CAP-V6
Post by B2CAP-V6 »
I have a big problem. I uninstalled FC11 and reinstalled it. Now I can't open a flowchart (it opens and disappears immediately, FC closes). I also can't create a new flowchart; the same thing happens!
I don't understand anything anymore.
I think there may be an issue with the updates on the website that is causing this problem. I will check now and let you know.
I found and fixed a problem. Is it working ok for you now?
B2CAP-V6
Post by B2CAP-V6 »
Now that FC11 is working, I tried compiling again and I still have the same problem.
I've attached the files.
Thermo_Baro.msg.txt
(5.2 KiB) Downloaded 475 times
Thermo_Baro.fcfx
(25.22 KiB) Downloaded 444 times
Have you downloaded and installed the FC11 PIC toolchain from Matrix website?
Ah, edit, I've just looked at your new msg.txt and see that you now have correct compiler.
Must be something else wrong.
Have you done a full component update?
Has thanked: 724 times
Been thanked: 783 times
I find this as odd.
Your project compiles for me without any alterations.
However your txt.msg file suggests a pin is not connected.
As Leigh as suggested have you done a full component database update?
