Supressed zero's
RGV250
Has thanked: 46 times
Been thanked: 48 times
Supressed zero's
Post by RGV250 »
I am not sure the title is correct, what annoys me (not only in FC) is when you have a value like 1.230 and it shows as 1.23 or 1.100 (1.1) and so on.
Is there a way of actually showing the zeroes, the bit that annoys me is the number is jumping around as the values change.
I did try changing the decimal places on the gauge but all that did was clutter up the display and did nothing for the digital readout.
Bob
Has thanked: 311 times
Been thanked: 479 times
Re: Supressed zero's
You could maybe hide the label on the gauge with a shape and use your own text label showing the value in the required format.
RGV250
Post by RGV250 »
Hi Steve,
If it were just a string output I would probably manipulate it but as the gauge is numeric I think I will leave it as it is and see how it goes with actual data later as it may not be a big issue.
