Question regarding the switch function, and a thought
alanwms
Has thanked: 26 times
Been thanked: 8 times
Post by alanwms »
Is it possible to use a string for the switch function?
Thought:
Such a simple idea, but it would be nice to incorporate either automatic or manual file backups.
Has thanked: 296 times
Been thanked: 459 times
Re: Question regarding the switch function, and a thought
If you mean the Switch command icon, then not exactly. That said, you can create a set of constants with appropriate names and unique integer values, and then use those throughout your project. These could then be used in a Switch statement and would be make the code a lot more readable and easy to understand.
As for your second point, there are automatic backup options in the Global Options screen.
Has thanked: 726 times
Been thanked: 785 times
Would the attached example work for you?
You can use single string chars for the switch function.
Using string for switch function.fcfx
(11.6 KiB) Downloaded 26 times
