STM32 I2C master BUG
Oscar_T
Has thanked: 37 times
Been thanked: 10 times
Post by Oscar_T »
With i2c master version 5 I can't compile my program
The compiler reports this message to me
"Errors when generating C source code:
Mainboard_013.c : 1 : error : Unknown or missing component: I2C_Master1::SendByteTransaction
Mainboard_013.c : 4359 : error : Unknown or missing component: I2C_Master1::SendByteTransaction
Autoclose turned off
If I use version 4 everything is ok
Kind regards
Kind Regards
Has thanked: 772 times
Been thanked: 833 times
Re: STM32 I2C master BUG
Hi, Oscar.
It looks the component has had the name of function SendByteTransaction changed to GenericWriteRegister.
If you would like to post your flowchart, or pm if you want to keep it private, I can sort it out for you.
If you want to manually change it yourself, then I can help you with that.
Oscar_T
Post by Oscar_T »
Hi Medelec
Thanks for the advice
I changed all SendByteTransaction with GenericWriteRegister. It compiles correctly but it doesn't work ...
Has something else changed or is it just a rename?
Kind regards
EDIT: Macros appear to be slightly different
Hi, yes the macros do look a bit different:
Component differences.png (87.47 KiB) Viewed 10350 times
The addressH and L has been changed to use one input which will cause an issue if not changed.
Hope this helps?
Oscar_T
Post by Oscar_T »
How can I set the new address in the new macro? it consists of two parts (H and L)
For example 0x38, 0x40, 0x0E, 0x10
maybe 0x38, 78, 0x10, 2 ?
Kind regards
As you already have the AddressHighByte & AddressLowByte
In the Address just enter the HighByte then lowByte straight after.
Eg using your example.
Since 0x38 is H and 0x40 is L.
For UInt address enter 0x3840
Has thanked: 635 times
Been thanked: 842 times
Hi Oscar,
Sorry for the inconvenience, hopefully the modification allows a bit more flexibility in future allowing for device support with 1 or 2 internal address bytes.
How about this.
0x38, 0x400E, 0x10, 0x02
The device address is as was, the Address high and low bytes have been combined together into a 16-bit value, the Data parameter is as was and the Address Byte count is how many bytes in the internal address: 1 or 2.
Oscar_T
Post by Oscar_T »
Hi ben & medelec
Thanks for your explanations. Now everything works!
Kind regards
