Main program Task Priority
gregobac
Post by gregobac »
I encounter a difficulty with the ESP32 real time in FC9.
I make a simple program to generate a 1 khz signal on the GPIO1
Every 5sec and during 40ms the signal is interrupted
I tried the same program with using interrupt on timer 0, 1 or 2 , the problem is same.
I tried the same code in IDE Arduino :
I have no interrupt of the 1 Khz signal
Is this problem due to FreeRTOS? And how to disable it?
Thank you for your help
Best regards
Has thanked: 595 times
Been thanked: 785 times
Re: Main program Task Priority
Probably a watchdog timeout kicking in and causing a reset.
Try this fix posted here.
https://www.flowcode.co.uk/forums/viewt ... 3568#p3568
gregobac
Post by gregobac »
Hello Ben,
Thank you very much !
Its works perfectly :D
