I'm trying to figure out how to be able to activate the various energy modes of esp32.
Could you kindly give some examples and indicate which libraries to include to activate the various modes and how to get out of the low-power modes?
Kind regards
Esp32 Power management
Oscar_T
- Has thanked: 37 times
- Been thanked: 10 times
- Has thanked: 595 times
- Been thanked: 785 times
Re: Esp32 Power management
This page should be useful, just call the required C calls using a C icon.
https://docs.espressif.com/projects/esp ... modes.html
Hey Oscar_T,
Did you manage to put the ESP32 into power down mode?
I want to reduce power by putting the ESP into some kind of sleep mode and return to wake every few minutes.
I don't know what's best: maintain the WIFI connection:
Any experience?
or go into it's deepest sleep and wake up and connect to wifi every time again..If WiFi connection needs to be maintained, enable WiFi modem sleep, and enable automatic light sleep feature (see Power Management APIs). This will allow the system to wake up from sleep automatically when required by WiFi driver, thereby maintaining connection to the AP.
Any experience?
- Has thanked: 157 times
- Been thanked: 911 times
A very simple example of light sleep with a timer...
Here the esp32 sleeps for 5 seconds before resuming output to the UART - experiment with other esp_sleep_enable_... functions to suit.
Note - this is only intended as a sample - it would probably be better to move the import of esp_sleep.h to supplementary code..
Power consumption (using a USB power tester - so not very accurate) falls from 0.005A to 0.00)
Note that deep sleep is different - here the MCU is actually reset on waking - so will go back to the start of the 'main' function on wake.
There is a way to save some state in the RTC AP memory - and, for example, use a flag to indicate that the program has just restarted. I'll have a go at getting this to work..
So - if you use
To enable a 5s deep sleep - you notice that the output to UART is 'Sleep in 1s' 6s pause 'Sleep in 1s' etc
So - if you use
esp_deep_sleep(5 * 1000 * 1000);Martin
Magnificent Martin! Thanks!
I've altered it so I can get feedback with the onboard LED.
I can see the current from the ESP32S Wroom drop form 30mA to 0mA.
My goal is to get the ESP in as low-power-mode as possible to get an ESP working on a 18650 battery as long as possible.
But I'm not sure which mode is best to maintain connection with WIFI.
The modes where WIFI connection is maintained would be best, but maybe this consumes more power.
I don't know if a router appreciates it if a device (ESP32) connects every minute and loses it's connection after sending data?
Note to myself.. Need to test if the RAM is kept during sleep.
Thanks Martin!
Thanks Martin!
Update to whom it may concern
(And otherwise for me to remember these values
I've put the ESP32S into the normal sleep and it draws 14mA (measured in the USB line that powers it).
This includes the power-on-LED.
The RAM is maintained in this light sleepmode and it returns back to the point where it ended.
12mA in deep sleep mode and 53mA when I wake it up and make the onboard LED flash.
Again with the power LED on.
In this mode it returns back to the start of the main of the program.
Need to find out how much power the module uses with the WIFI enabled, maybe the Bluetooth radio..
To do: order some more boards and desolder the powerled.
More testing...
esp_light_sleep_start();Again with the power LED on.
esp_deep_sleep(15 * 1000 * 1000);Need to find out how much power the module uses with the WIFI enabled, maybe the Bluetooth radio..
More testing...
It's interesting - the wifi is going to use some power - but a connection will not be maintained in either light or deep sleep.
An alternate power save route is to reduce the clock speed... (see https://docs.espressif.com/projects/esp ... ement.html)
Anyway - I tried maintaining some RAM.. Here just two values - a flag which is set to 123 when the program first runs and a restart counter that is initially set to 0 and is incremented by 1 each time the MCU resets. Note that the output to UART display this count and also all the 'debug' info that the esp32 puts out on restart (this can probably be turned off in config?)
Here I just enter deep sleep for 1s and restart 10 times before the program terminates...
The RTC memory is at address 0x50000000 (and there is 8k (words?) available) - RTC_SLOW_MEM is defined in supplementary code and can be used like an 'array' in a C block.
So I guess for maximum power saving the connection needs to be made on each power on..WiFi/BT and sleep modes
In deep sleep and light sleep modes, wireless peripherals are powered down. Before entering deep sleep or light sleep modes, applications must disable WiFi and BT using appropriate calls (esp_bluedroid_disable(), esp_bt_controller_disable(), esp_wifi_stop()). WiFi and BT connections will not be maintained in deep sleep or light sleep, even if these functions are not called.
Hey Martin,
By testing it I got to know why this workaround.
If the ESP reboots after sleep, the whole RAM is cleared, and you found a way to store a value even if the module reboots.
NICE!!!
I guess that was your purpose?
I'm not looking to have the module working for years on 1 battery charge, but it would be nice to have it running every 10 minutes with one battery charge (I think I will use a 18650), and that for a week or so.
This will work I guess if I can reduce power and starting by removing the power-on-led.
If other tricks can be applied without making the program too complicated, I will try this too.
For me, this trick by storing the value in a RAM that is maintained is very very nice.
This means that I can sample a value and store it, go to sleep for 10 minutes, resample the value and only if the values are not the same: start WIFI, connect.... go to sleep... This means that I don't have to use the WIFI unnecessary. (and safe power).
Thanks again and keep the tips coming
I need to test the power consumption with WIFI enabled.
NICE!!!
There is a lot of power 'hidden' in the esp32.... For example it is possible to write a program for the low power processor that reads a sensor and only wakes the 'main' MCU if the data has changed.
I found https://blog.voneicken.com/2018/lp-wifi-esp32-1/ - which looks at some techniques for maximizing battery life by speeding up wi-fi connection. I think the techniques should be applicable in Flowcode.
As an aside - I was given a weather station kit for Christmas (just the sensors) - and spent some time trying to get it working with an esp32 - the anemometer worked well - but the wind direction I struggled with - the sensor has 16 possible resistance values and by using a second known resistor can be used as part of voltage divider..
However - all my attempts to correctly read the voltage correctly failed. By varying the value of the known resistor - I was able to check ~12/16 directions correctly. I'd put it aside - other things needing time - and planned to return (it's currently way too windy here to risk it outside) - but if anyone has any advice/experience of this?
I'd also struggled to work a way to get a 'web' page displaying current conditions - if the esp32 is 'sleeping' then an error is displayed.
I'd also almost resorted to using an ATTiiny and nrf24l01 which can wake the MCU when a data request is received. However, the bits you've posted here (and other topics) have encouraged me to try again with the esp32 and a web 'interface'.
