ESP32 Bluetooth SPP
Alan_37
Has thanked: 55 times
Been thanked: 27 times
ESP32 Bluetooth SPP
Post by Alan_37 »
Hi , I would like to use the esp32 Bluetooth on the help page it says "BT Legacy functionality must be switched on via the sdkconfig file"
but I don't have any idea how to do that anyone can help, please?
Has thanked: 560 times
Been thanked: 744 times
Re: ESP32 Bluetooth SPP
In the Flowcode project directory should be a folder that is created when you compile. Inside this folder is a file called sdkconfig.
Open this file with a text editor e.g. notepad++ and look for this section.
# Bluetooth
The default is that BLE_ONLY is enables and so need to change the setting to look like this instead.
# Bluetooth
CONFIG_BT_ENABLED=y
# Bluetooth controller
# CONFIG_BTDM_CTRL_MODE_BLE_ONLY is not set
CONFIG_BTDM_CTRL_MODE_BR_EDR_ONLY=y
# CONFIG_BTDM_CTRL_MODE_BTDM is not set
Once you've done this save the config file and recompile the project.
Hope that helps.
Alan_37
Post by Alan_37 »
Hi Ben,
I have edited the file as you told me but I still can't see the esp when
I scan the Bluetooth for new devices.
Also, I noticed that if I Initialize WLAN and BT together the esp will not boot correctly and panic
can WLAN and Bluetooth be used together?
sdkconfig.rar
(8.88 KiB) Downloaded 558 times
Flowcode1.fcfx
(15.9 KiB) Downloaded 528 times
Alan_37
Post by Alan_37 »
So is this a bug ? or i am doing something wrong ?
Alan_37
Post by Alan_37 »
Any help on this, please?
Reading around the subject it looks like BT and WIFI should be able to run at the same time on the ESP, but this does not specifically mention the EDR mode.
I'll see if I can find out any further info for you.
luibra63
Has thanked: 1 time
Been thanked: 4 times
Post by luibra63 »
Good morning
I have the same problem, I programmed the device with this file and modified the "sdkconfig" file as indicated but I don't see the ble on the phone; I noticed, however, that the modified and saved file, when I compile the next time the modification, the file returns as before the modification. do you have any news?
Best Regards
