Can it be possible to make library for MAX7219 driver for dot matrix 8 x 8 pixels for 4 digits in one line? How approximally it can be cost?
I am interesting in it very much. I have this dot matrix and I want to do "2022" scroll line on it for New Year and I want put this on my window. Let other people see because no one have this.
I hope you understand. I am a little in english, so sorry for any mistakes.
MAX7219 DOT MATRIX 8 x 8 Pixels
Sergejs
- Has thanked: 75 times
- Been thanked: 5 times
- Has thanked: 177 times
- Been thanked: 1026 times
Re: MAX7219 DOT MATRIX 8 x 8 Pixels
See https://www.flowcode.co.uk/mmforums/vie ... 9&start=25
Download the component from the end of the message chain - and see if you can get things working. If any problems - ask here....
- Has thanked: 902 times
- Been thanked: 218 times
Hi Sergejs!
Our good friend Martin create a component for me (and other) here: https://www.flowcode.co.uk/mmforums/vie ... 219#p90355 and it working perfect, can do many funny thing
It was created for FC8 but I suppose this also work in FC9. A good idea, read the whole thread. You have to install the component macro
I think I have some examble somewhere on my PC, I will have a look and I will share if you want.
Edit: Well Martin we answer at same time
Br Jorgen
Br Jorgen
Sorry, but I can not find and download library for max7219 in that forum. I get file but it can not be run because no library for max7219.
4 dot matrix one by other and I need run it with scroll digits.
Can you please help me with it?
May be we can use Team Viever and someone can show me how it makes? Or is there anywhere file with component library?
Hi Sergejs!
@Martin help me if I am wrong
The att. component, Fcpx place it in a lib. Maybe you have a Lib for all your projects. Name the lib. Max7219 and place the file in there.
Then you open FC9 find wiev > Global settings > Locations. In location you find "look for components in" On rigth side you find a tab, click on this, find
the lib where you place the Max7219 component. Restart FC9 and make a new project, in component lib. use search for max7219 and add it to the panel, then you are on the run.
I have still not test in FC9.
Lot of step, but not so tricky. When you have to play and test,you have to play with all the macro to get experience with the component. 'thank´s to Martin, it can do lot of funny thing.
One of my project https://www.youtube.com/watch?v=83j3dUt ... enGundorph
Br Jorgen
Br Jorgen
- testScrolVirker.fcfx
- (8.11 KiB) Downloaded 884 times
- (view online)
- max7219 multi 2.fcfx
- (65.2 KiB) Downloaded 875 times
- (view online)
- Max7219_v2.fcpx
- (8.31 KiB) Downloaded 815 times
Jorgen beat me to it this time !
I got a 'Hello World' running too - it seems to work in v9..
A couple of points I would add...
The wiring is quite critical - a lot of very thin jumper wires won't work reliably (or at all) - I plugged the display directly into an Arduino - and used a data pin set high as Vcc and one low as Gnd
After calling InitialiseLED - the display is Initialised but 'off' - so you need to call ShutDown(false) before anything will be displayed. (No - I don't know why I did it like this...)
Set the brightness fairly low - particularly if powering off an MCU pin.
As far as I remember it will support up to 16 8x8 displays. (Somewhere on the Matrix forum there is a 'snake' and game of life I did on a 4 x 4 (so 32 x 32 LEDs) display)
Jorgen ably demonstrated all this...
You 'might' need to do Output(pin10, 1) on an Arduino to get SPI working correctly.
