Callbacks in Flowcode.
Has thanked: 165 times
Been thanked: 967 times
Post by mnfisher »
Callbacks don't seem to be implemented..
Define a property of type 'Macro Call' - and this can be assigned to any of the available macros in a program.
Unfortunately it doesn't get assigned within the program - and there doesn't seem to be a way to call the macro. E.g. macro_var(1); in a C block or (without the ;) in a calculation block..
Has thanked: 294 times
Been thanked: 459 times
Re: Callbacks in Flowcode.
There is a built-in (aka "simulation") macro called "CallMacro". This will take the variable given by the "Macro Call" property.
Post by mnfisher »
Thanks Steve,
Will experiment - or is it just simulation?
I did find an easy workaround :D
Yes - this function is simulation-only.
